Date/Time: Thu, 06 Feb 2025 00:00:49 +0000
Bad Ticks on Bid Ask Spread when in Simulation Mode and/or replay and Backtest
View Count: 629
[2020-04-08 13:31:30] |
User100812 - Posts: 2 |
Constantly get bad ticks always approx. 64 POINTS away from the market on a losing trade only. The settled price then picks up the bad tick and shows a loss of $3,200 +/- on the emini /ES. Even if replay is set to a speed of 1 this occurs. Any suggestions - I can't backtest and that is a problem. |
[2020-04-08 18:09:42] |
This is due to the data provided by the Transact data feed. Please consider using this data feed which is provided by Sierra Chart: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
