Date/Time: Wed, 30 Oct 2024 22:55:54 +0000
Trial Account Activated But Nothing seems supported
View Count: 1114
[2014-01-13 19:26:17] |
User94614 - Posts: 13 |
Current Service Package: Trial Package (Activated) Not Connected! Checking for new symbol settings for tda | 2014-01-13 14:14:55 Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-01-13 14:15:00 Current selected Data/Trading service: TD Ameritrade | 2014-01-13 14:18:52 Your current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2014-01-13 14:19:31 |
[2014-01-13 20:48:08] |
Restart Sierra Chart and on the Login window enable the "Force Login" option.
[2014-01-14 14:15:12] |
Thanks, that worked.
