Date/Time: Wed, 05 Feb 2025 23:56:28 +0000
OCO
View Count: 570
[2020-04-08 00:27:30] |
John Ara - Posts: 125 |
When I send my orders directly from charts, my attached orders are not being attached as child orders. Please help me know how to have them attached while chart trading. Thank you. |
[2020-04-08 07:01:41] |
Make sure you you have enabled the Use Attached Orders setting on the Trade Window associated with the chart: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-09 00:01:16] |
Even with that checkmark, when sending orders from chart, it does not attach my oco's while it attaches when sending from DOM the same order
