Date/Time: Tue, 15 Sep 2026 14:19:34 +0000
[Programming Help] - Horizontal Line: Name & Value Display
View Count: 943
[2020-04-07 21:05:12]
User184576 - Posts: 23
I would like to code both name and value display properties into a custom study.
I've only been able to achieve one or the other, but not both simultaneously
I assume I'm missing a reference and/or my syntax is incorrect.
Any assistance would be appreciated.
Thank you!
//Line Attributes
//Set Subgraphs To Display Price On Far Right Side Of Chart And Center Vertically
//Set Subgraphs To Display Name On Far Left Side Of Chart And Center Vertically
PreviousCloseLine.LineLabel = LL_DISPLAY_NAME | LL_NAME_ALIGN_CENTER | LL_NAME_ALIGN_LEFT_EDGE;
PreviousCloseLine.LineLabel = LL_DISPLAY_VALUE | LL_VALUE_ALIGN_CENTER | LL_VALUE_ALIGN_FAR_RIGHT;
[2020-04-08 06:54:25]
User907968 - Posts: 883
Set the name and value properties in a single operation, if you do them separately you are simply overwriting the previous value.
PreviousCloseLine.LineLabel = LL_DISPLAY_NAME | LL_NAME_ALIGN_CENTER | LL_NAME_ALIGN_LEFT_EDGE | LL_DISPLAY_VALUE | LL_VALUE_ALIGN_CENTER | LL_VALUE_ALIGN_FAR_RIGHT;
Alternatively you could use the |= (or equals) compound assignment operator when assigning the second set of properties
PreviousCloseLine.LineLabel |= LL_DISPLAY_VALUE | LL_VALUE_ALIGN_CENTER | LL_VALUE_ALIGN_FAR_RIGHT;
[2020-04-08 13:24:29]
Thank you - I appreciate it!
