Date/Time: Tue, 29 Sep 2026 00:38:03 +0000
[Programming Help] - Spreadsheet programming - locking one time event
View Count: 1096
| [2020-04-07 19:11:13] |
| User183724 - Posts: 194 |
need to save (freeze) a copy of current line 3 of the [ID0.SG1] Open [ID0.SG2] High [ID0.SG3] Low [ID0.SG4] Last when K3 or M3 go from 0 to 1. Don't need to keep after K3/M3 return to 0. could use the same area to store the next occurrence. I'm working with this Locking the State of a One Time Condition Spreadsheet Studies Special Tasks and this Spreadsheet Example Formulas and Usage: Persistent and Incrementing Variables Persistent and Incrementing Variables can't quite get it to work and reset correctly. any assistance appreciated. thx tim |
| [2020-04-07 19:30:41] |
| Sawtooth - Posts: 4355 |
Try this in Q3: =IF(K3=0,0,IF(AND(K4=0,K3>0),B3,Q4)) This will make the Open price persistent in column Q when K3 goes true, and return to 0 when K3 goes false. You'll need a separate Formula Column for each of the 4 values. You can use the shorter B3, C3, D3, E3 instead of ID0.SG1@3, ID0.SG2@3, ID0.SG3@3, ID0.SG4@3 |
| [2020-04-07 23:35:57] |
thank you
