Date/Time: Wed, 05 Feb 2025 23:50:58 +0000
How deactivate confirmations for one click trading?
View Count: 851
[2020-04-07 15:11:39]
rainbow47 - Posts: 68
I am having problems with the Chart Trade Window and the order confirmation. I press on "Menu" and deselct all te confrimations because I trade on one click. It works for one trade but when I want to do the second trade a confirmation window pops up again.
Any idea how to deactivate it and have one click always activated when I satrt SC?
[2020-04-07 19:48:20]
Once you deactivate the Order Confirmations for a chart, they should remain deactivated. Make sure you also save the Chartbook after you have made the change:
Chartbooks (Workspaces): To Save a Chartbook
Also, keep in mind that the option for changing the Order Confirmations from the Menu tab of the Trade Window is per chart. Therefore, it only applies to the specific chart that the Trade Window is associated with. You would then need to do this for each chart in order to have their confirmations off. Refer to the information here:
Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM
Finally, be aware of the option to turn off the Order Confirmations globally. Refer to the information here:
Global Trade Settings Windows: Disable Order Confirmations - Global (Global Settings >> Chart Trade Settings >> General >> Confirmations)
Date Time Of Last Edit: 2020-04-07 19:48:56
