Date/Time: Wed, 05 Feb 2025 23:53:46 +0000
symbol not found
View Count: 758
[2020-04-07 13:21:51]
User244592 - Posts: 46
Using latest IB api and latest TWS. Since I went to 2074 every time I load a chart the orange box pops up - symbol not found. If I enter the stock symbol into the find symbol to open a new chart this does not happen. If I open a quote board every symbol I click on gives orange box and if I change symbol using chart settings gives box also. As far as I can tell only with stock symbols, I tried NISS-SP and that was OK. On the quote board the last price updated but the daily change is zero, on the chart both are correct.
Date Time Of Last Edit: 2020-04-07 19:31:33
[2020-04-07 19:38:44]
Tell us one of the symbols that gives the error.
[2020-04-07 20:58:26]
MSFT
[2020-04-08 04:15:10]
After this, open a chart for that symbol and follow the instructions below:
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
