Date/Time: Sat, 18 May 2024 04:54:29 +0000
Sierra-yearly payment and Dinali
View Count: 641
[2020-04-06 22:15:09] |
Stupid - Posts: 30 |
Hi I wanted to know how to pay for the entire year and get the chart/Dinali at at discounted value and also how can I get a second Dinali Thanks |
[2020-04-08 10:19:24] |
In order to get Sierra Chart at the Yearly discount, go to the following page and in the section for Choose Service Package and Time Period for Usage Time select the yearly service package and select the Update/Set button: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation The Denali Exchange Data Feed is only paid monthly and there are no discounts for this. With regards to a second Denali Exchange Data Feed - if you want the data on the same computer, then just follow the directions here: Using DTC Server for Data and Trading in Another Sierra Chart Instance If you want a second Denali on a second computer, then you would need another account also with the Denali Exchange Data Feed. This we can provide for 50% off. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-09 11:10:16] |
Ok i have sierra on 2 computers but dinali works on one computer and I have to create a new sierra account so I have to pay for that sierra package too right- am I assuming correctly so I have to pay for a new sierra package? its in response to the answer below If you want a second Denali on a second computer, then you would need another account also with the Denali Exchange Data Feed. This we can provide for 50% off |
[2020-04-09 20:22:06] |
We are working on setting up the ability to have 2 connections using the Denali Exchange Data Feed, wherein you will have to pay for the Exchange Fees, but we do not have that ready yet. Therefore, the only option available is to have the second account also with the Denali feed.
