Date/Time: Fri, 03 May 2024 21:05:25 +0000
Link Trading Account
View Count: 512
[2020-04-06 15:56:52] |
User755412 - Posts: 14 |
Can you please send the form over for me to link my AMP Trading Account? Thanks!
[2020-04-06 17:44:23] |
SC Support - Posts: 1797 |
If you mean to connect TTFIX Order Routing, see here: https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm |
[2020-04-06 17:48:47] |
All I would like to do at this point is link my Trading Account with AMP to Sierra Charts so I can finally get a live data feed. Is this the form I need?
[2020-04-06 18:33:05] |
Yes if the account is set up on the TT system that would be the right form. If it is with CQG , then you just need to follow the instructions here: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
