Date/Time: Fri, 03 May 2024 22:41:48 +0000
Options on futures Time and Sales?
View Count: 757
[2020-04-06 15:29:11] |
CaptEZ - Posts: 4 |
I can pull up Time and Sales windows for options on futures. It looks to be working however the Volume column always reads 0. Am I doing something wrong? Is this volume available? Im guessing its missing because it is CBOE data?...Thanks
[2020-04-06 18:43:37] |
Tell us one of the symbols you are looking at Time and Sales for.
[2020-04-06 19:00:09] |
CaptEZ - Posts: 4 |
I finally see some small volume numbers this morning looking at the 2700 and 2800 strikes. It is still interesting that the Time and Sales are changing frequently, but still shows 0 for volume on most lines. I pulled up: ESM20 P2600.FUT_OPT.CME as well as calls It has all the data columns and looks to be actively trading, but volume only shows 0. I also pulled up the 2500 strike as well. I am using Interactive Brokers, but just switched over to Denali data this morning Date Time Of Last Edit: 2020-04-07 12:11:41
