Date/Time: Thu, 06 Feb 2025 09:12:11 +0000
Using 2nd Instance of SC Exchange Data Feed on the Same System
View Count: 1007
[2020-04-06 12:54:21] |
RMos22 - Posts: 27 |
I'm getting this message on the 2nd instance 'Not connected to Live trading account to receive CME realtime futures data at non-professional fees'. I checked the 2nd instance and I'm getting real time data when compared to the main instance. Is there soemthing I need to do or should I just ignore this message? |
[2020-04-06 17:48:26] |
If it is a sub instance you can ignore that message. However, provide the Message Log from the main instance: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-06 18:59:46] |
Below is the message log in the main instance: Software version: 2078 64-bit | 2020-04-06 14:57:30.326 OpenGL enabled | 2020-04-06 14:57:30.326 Primary Thread ID: 17424 | 2020-04-06 14:57:30.326 Usage end date: 2020-05-04 | 2020-04-06 14:57:30.326 Enabled for: Advanced Features 2. | 2020-04-06 14:57:30.326 Enabled for: Sierra Chart Historical Data Service. | 2020-04-06 14:57:30.326 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2020-04-06 14:57:30.326 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-04-06 14:57:30.326 Enabled for exchange: INDEXES_DATA_BARCHART | 2020-04-06 14:57:30.326 Enabled for exchange: CME (Trading Account Required) | 2020-04-06 14:57:30.326 Enabled for exchange: CBOT (Trading Account Required) | 2020-04-06 14:57:30.326 Enabled for exchange: COMEX (Trading Account Required) | 2020-04-06 14:57:30.326 Enabled for exchange: NYMEX (Trading Account Required) | 2020-04-06 14:57:30.326 Received 1 data feed usernames. | 2020-04-06 14:57:30.326 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-04-06 14:57:30.326 Current selected Data/Trading service: SC Data - All Services | 2020-04-06 14:57:30.326 Custom symbol settings values: disabled | 2020-04-06 14:57:30.326 Chart Update Interval: 100 | 2020-04-06 14:57:30.326 Intraday Data Storage Time Unit: 0 | 2020-04-06 14:57:30.326 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-04-06 14:57:30.326 2020-04-06 14:57:30 Local computer time | 2020-04-06 14:57:30.326 2020-04-06 18:57:30 Local computer time in UTC | 2020-04-06 14:57:30.326 2020-04-06 14:57:30 Local computer time in SC Time Zone | 2020-04-06 14:57:30.326 2020-04-06 12:37:56 Server time in UTC | 2020-04-06 14:57:30.326 Local computer UTC time and Server UTC time difference: 0 seconds. | 2020-04-06 14:57:30.326 Program path: C:\SierraChart\ | 2020-04-06 14:57:30.326 Data Files path: C:\SierraChart\Data\ | 2020-04-06 14:57:30.326 OS Version Number: 10.0 | 2020-04-06 14:57:30.326 Locale Setting: C | 2020-04-06 14:57:30.326 DLLs: Convergent.dll, Convergent_64.dll, Convergent_64old.dll, emini-player.dll, emini-player_64.dll, ETOFSv3.dll, ETOFSv3_64.dll, harmonicPatterns.DLL, harmonicPatterns_64.DLL, HPC_Sierra.DLL, HPC_Sierra_64.DLL, MAutoFloorCeiling.dll, MAutoFloorCeiling_64.dll, MBidAskOscillator.dll, MBidAskOscillator_64.dll, MBoxChart.dll, MBoxChart_64.dll, MBoxHistogram.dll, MBoxHistogram_64.dll, MCumulativeDelta.dll, MCumulativeDelta_64.dll, MGannSwing.dll, MGannSwing_64.dll, MPace.dll, MPace_64.dll, MWaveChart.dll, MWaveChart_64.dll | 2020-04-06 14:57:30.328 File >> Disconnect selected. | 2020-04-06 14:57:33.494 DTC Client socket (1) | CloseSocket call. | 2020-04-06 14:57:33.652 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:33.652 SC Data - All Services | Disconnected from the server. | 2020-04-06 14:57:33.652 DTC Client socket (2) | CloseSocket call. | 2020-04-06 14:57:33.653 DTC Client socket (2) | 54 bytes remaining in receive buffer when socket closed. | 2020-04-06 14:57:33.653 SC DTC Data with Market Depth | Disconnected from the server. | 2020-04-06 14:57:33.653 SC Data - All Services | Disconnected. | 2020-04-06 14:57:33.653 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:33.653 DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-04-06 14:57:33.683 DTC Client socket (2) | Closed. | 2020-04-06 14:57:33.683 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-04-06 14:57:33.764 DTC Client socket (1) | Closed. | 2020-04-06 14:57:33.764 SC Data - All Services | Connected to data server. | 2020-04-06 14:57:51.425 Triggering next historical data download in queue. | 2020-04-06 14:57:51.425 Triggering next historical data download in queue. | 2020-04-06 14:57:51.426 Triggering next historical data download in queue. | 2020-04-06 14:57:51.426 Triggering next historical data download in queue. | 2020-04-06 14:57:51.426 Mapping ESM20 to ESM20. Service code: cme | 2020-04-06 14:57:51.575 SC Data - All Services | Starting real-time market data updates for: ESM20 (ESM20). ID: 1 Service code: cme | 2020-04-06 14:57:51.575 SC Data - All Services | Using username 0 | 2020-04-06 14:57:51.575 SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10048 | 2020-04-06 14:57:51.575 SC Data - All Services | Requesting security definition data for: ESM20 (ESM20). ID: 1 | 2020-04-06 14:57:51.575 Added historical Intraday data request for ESM20 to the queue. | 2020-04-06 14:57:51.575 Intraday data recording state for symbol ESM20 is set to download 'Pending'. | 2020-04-06 14:57:51.575 TICK-NYSE [CBV-D][M] 2 Min #39 | Started historical data download for additional symbol ESM20. Download ID: 38 | 2020-04-06 14:57:51.575 DTC Client socket (1) | Creating socket. | 2020-04-06 14:57:51.575 DTC Client socket (1) | Connecting to IP: 8.18.161.133. | 2020-04-06 14:57:51.575 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 2 Service code: statscalc | 2020-04-06 14:57:51.575 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2020-04-06 14:57:51.575 SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 2 | 2020-04-06 14:57:51.575 Added historical Intraday data request for NISS-NYSE to the queue. | 2020-04-06 14:57:51.575 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2020-04-06 14:57:51.575 TICK-NYSE [CBV-D][M] 2 Min #39 | Started historical data download for additional symbol NISS-NYSE. Download ID: 39 | 2020-04-06 14:57:51.575 DTC Client socket (2) | Creating socket. | 2020-04-06 14:57:51.575 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2020-04-06 14:57:51.575 Delaying start of download for ESM20 | 2020-04-06 14:57:51.593 SC Data - All Services | Connected to server. | 2020-04-06 14:57:51.615 SC Data - All Services | Starting socket receive thread. | 2020-04-06 14:57:51.615 SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-04-06 14:57:51.615 SC DTC Data with Market Depth | Connected to server. | 2020-04-06 14:57:51.615 SC DTC Data with Market Depth | Starting socket receive thread. | 2020-04-06 14:57:51.615 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2020-04-06 14:57:51.615 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:51.659 SC DTC Data with Market Depth | Sending logon request message. | 2020-04-06 14:57:51.659 SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:51.666 SC Data - All Services | Sending logon request message. | 2020-04-06 14:57:51.666 Mapping RTYM20 to RTYM20. Service code: cme | 2020-04-06 14:57:51.703 SC Data - All Services | Starting real-time market data updates for: RTYM20 (RTYM20). ID: 3 Service code: cme | 2020-04-06 14:57:51.703 SC Data - All Services | Requesting security definition data for: RTYM20 (RTYM20). ID: 3 | 2020-04-06 14:57:51.703 Added historical Intraday data request for RTYM20 to the queue. | 2020-04-06 14:57:51.704 Intraday data recording state for symbol RTYM20 is set to download 'Pending'. | 2020-04-06 14:57:51.704 Triggering next historical data download in queue. | 2020-04-06 14:57:51.704 SC Data - All Services | Received logon response. | 2020-04-06 14:57:51.729 SC Data - All Services | Server Name: SC Realtime Server. | 2020-04-06 14:57:51.729 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-04-06 14:57:51.729 SC Data - All Services | Successfully connected. | 2020-04-06 14:57:51.729 SC Data - All Services | Trading is not supported. | 2020-04-06 14:57:51.729 SC Data - All Services | Restarting real-time data updates for symbol: ESM20 -> ESM20 | 2020-04-06 14:57:51.729 SC Data - All Services | Restarting real-time data updates for symbol: RTYM20 -> RTYM20 | 2020-04-06 14:57:51.729 SC Data - All Services | Received security definition for symbol ESM20 | 2020-04-06 14:57:51.804 SC Data - All Services | Received security definition for symbol RTYM20 | 2020-04-06 14:57:51.804 Mapping NQM20 to NQM20. Service code: cme | 2020-04-06 14:57:51.805 SC Data - All Services | Starting real-time market data updates for: NQM20 (NQM20). ID: 4 Service code: cme | 2020-04-06 14:57:51.805 SC Data - All Services | Requesting security definition data for: NQM20 (NQM20). ID: 4 | 2020-04-06 14:57:51.805 Added historical Intraday data request for NQM20 to the queue. | 2020-04-06 14:57:51.805 Intraday data recording state for symbol NQM20 is set to download 'Pending'. | 2020-04-06 14:57:51.805 Triggering next historical data download in queue. | 2020-04-06 14:57:51.805 SC Data - All Services | Received security definition for symbol NQM20 | 2020-04-06 14:57:51.869 SC DTC Data with Market Depth | Starting real-time market data updates for: TICK-NYSE. ID: 5 Service code: statscalc | 2020-04-06 14:57:51.911 SC DTC Data with Market Depth | Requesting security definition data for: TICK-NYSE. ID: 5 | 2020-04-06 14:57:51.911 Added historical Intraday data request for TICK-NYSE to the queue. | 2020-04-06 14:57:51.911 Intraday data recording state for symbol TICK-NYSE is set to download 'Pending'. | 2020-04-06 14:57:51.911 Triggering next historical data download in queue. | 2020-04-06 14:57:51.911 Mapping YMM20 to YMM20. Service code: cbot | 2020-04-06 14:57:52.059 SC Data - All Services | Starting real-time market data updates for: YMM20 (YMM20). ID: 6 Service code: cbot | 2020-04-06 14:57:52.059 SC Data - All Services | Requesting security definition data for: YMM20 (YMM20). ID: 6 | 2020-04-06 14:57:52.059 Added historical Intraday data request for YMM20 to the queue. | 2020-04-06 14:57:52.059 Intraday data recording state for symbol YMM20 is set to download 'Pending'. | 2020-04-06 14:57:52.059 Triggering next historical data download in queue. | 2020-04-06 14:57:52.059 SC Data - All Services | Received security definition for symbol YMM20 | 2020-04-06 14:57:52.105 SC DTC Data with Market Depth | Received logon response. | 2020-04-06 14:57:52.242 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2020-04-06 14:57:52.242 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2020-04-06 14:57:52.242 SC DTC Data with Market Depth | Successfully connected. | 2020-04-06 14:57:52.242 SC DTC Data with Market Depth | Trading is not supported. | 2020-04-06 14:57:52.242 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2020-04-06 14:57:52.242 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICK-NYSE | 2020-04-06 14:57:52.242 SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2020-04-06 14:57:52.286 SC DTC Data with Market Depth | Received security definition for symbol TICK-NYSE | 2020-04-06 14:57:52.286 Mapping ZBM20 to ZBM20. Service code: cbot | 2020-04-06 14:57:52.398 SC Data - All Services | Starting real-time market data updates for: ZBM20 (ZBM20). ID: 7 Service code: cbot | 2020-04-06 14:57:52.398 SC Data - All Services | Requesting security definition data for: ZBM20 (ZBM20). ID: 7 | 2020-04-06 14:57:52.398 Added historical Intraday data request for ZBM20 to the queue. | 2020-04-06 14:57:52.398 Intraday data recording state for symbol ZBM20 is set to download 'Pending'. | 2020-04-06 14:57:52.398 Triggering next historical data download in queue. | 2020-04-06 14:57:52.398 SC Data - All Services | Received security definition for symbol ZBM20 | 2020-04-06 14:57:52.462 HD Request # 38 | Downloading Intraday chart data for ESM20 to the file ESM20.scid. Service: cme | 2020-04-06 14:57:56.043 HD Request # 38 | Download start date-time: 2020-04-06 14:57:32.000 | 2020-04-06 14:57:56.044 HD Request # 38 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2020-04-06 14:57:56.044 Socket (3) | Creating socket. | 2020-04-06 14:57:56.045 Socket (3) | Connecting to IP: 8.18.161.135. | 2020-04-06 14:57:56.045 HD Request # 38 | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:56.113 HD Request # 38 | Sending historical data logon request message. | 2020-04-06 14:57:56.113 HD Request # 38 | Requesting Intraday data. Start date-time: 2020-04-06 14:57:32. Record interval: 0. Symbol: ESM20 | 2020-04-06 14:57:56.141 HD Request # 38 | Decompressing data. | 2020-04-06 14:57:56.168 HD Request # 38 | Receiving Intraday data for ESM20 starting at 2020-04-06 14:57:32 | 2020-04-06 14:57:56.169 Socket (3) | CloseSocket call. | 2020-04-06 14:57:56.170 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:56.170 Historical data download thread signaled to stop. | 2020-04-06 14:57:56.192 HD Request # 38 | Timestamp of first Intraday data file record written: 2020-04-06 14:57:34 | 2020-04-06 14:57:56.192 HD Request # 38 | Received 671 records from 2020-04-06 14:57:32.000 to 2020-04-06 14:57:53.005 (21.0 seconds) and wrote 669 records for ESM20 | 2020-04-06 14:57:56.192 Added 31 Time and Sales records to Intraday data file for ESM20 after download. | 2020-04-06 14:57:56.193 HD Request # 38 | Completion time: 0s | 2020-04-06 14:57:56.193 HD Request # 38 | Intraday data download complete for ESM20. Unique request ID: 38 | 2020-04-06 14:57:56.193 Removing historical data download ID 38. | 2020-04-06 14:57:56.193 Real-time Intraday chart data file updates started for ESM20 | 2020-04-06 14:57:56.193 Intraday chart data file opened for ESM20 | 2020-04-06 14:57:56.193 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2020-04-06 14:57:56.193 TICK-NYSE [CBV-D][M] 2 Min #39 | Historical data download for additional symbol ESM20 with ID 38 has completed. | 2020-04-06 14:57:56.193 Triggering next historical data download in queue. | 2020-04-06 14:57:56.193 Delaying start of download for NISS-NYSE | 2020-04-06 14:57:56.193 Socket (3) | Socket gracefully closed by remote side. | 2020-04-06 14:57:56.199 Socket (3) | Closed. | 2020-04-06 14:57:56.199 Chart #64 has tagged chart #22 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.371 Chart #64 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.371 ESM20 [CBV][M] 5 Min #22 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.408 Chart #22 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.409 Chart #22 has tagged chart #33 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.409 Chart #22 has tagged chart #7 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.409 Chart #22 has tagged chart #70 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.409 ESM20 [CBV][M] 1 Min #70 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.426 ESM20 [CBV][M] 1 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.465 Chart #52 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.740 ESM20 [CBV][M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.848 Chart #7 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.849 Chart #7 has tagged chart #70 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.849 Chart #51 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.872 Chart #65 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.881 ESM20 [CBV][M] 15 Min #33 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.965 Chart #33 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.967 Chart #33 has tagged chart #7 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.967 Chart #33 has tagged chart #70 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:56.967 ESM20 [CBV][M] 1 Min #70 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:57.183 ESM20 [CBV][M] 1 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:57.223 HD Request # 39 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2020-04-06 14:57:57.461 HD Request # 39 | Download start date-time: 2020-04-06 14:57:33.000 | 2020-04-06 14:57:57.461 HD Request # 39 | Using server: ds4.sierracharts.com port 10150 | 2020-04-06 14:57:57.461 Socket (4) | Creating socket. | 2020-04-06 14:57:57.462 Socket (4) | Connecting to IP: 192.81.56.146. | 2020-04-06 14:57:57.462 HD Request # 39 | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:57.534 HD Request # 39 | Sending historical data logon request message. | 2020-04-06 14:57:57.534 ESM20 [CBV][M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:57.589 Chart #7 has tagged chart #27 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:57.590 Chart #7 has tagged chart #70 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:57.590 ESM20 [CBV][M] 1 Min #70 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:57.930 ESM20 [CBV][M] 1 Min #27 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:57.973 HD Request # 39 | Requesting Intraday data. Start date-time: 2020-04-06 14:57:33. Record interval: 0. Symbol: NISS-NYSE | 2020-04-06 14:57:58.065 HD Request # 39 | Decompressing data. | 2020-04-06 14:57:58.114 HD Request # 39 | Receiving Intraday data for NISS-NYSE starting at 2020-04-06 14:57:33 | 2020-04-06 14:57:58.114 Socket (4) | CloseSocket call. | 2020-04-06 14:57:58.114 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:58.114 Socket (4) | Socket gracefully closed by remote side. | 2020-04-06 14:57:58.154 Socket (4) | Closed. | 2020-04-06 14:57:58.154 Historical data download thread signaled to stop. | 2020-04-06 14:57:58.214 HD Request # 39 | Timestamp of first Intraday data file record written: 2020-04-06 14:57:34 | 2020-04-06 14:57:58.215 HD Request # 39 | Received 25 records from 2020-04-06 14:57:33.000 to 2020-04-06 14:57:57.000 (24.0 seconds) and wrote 24 records for NISS-NYSE | 2020-04-06 14:57:58.215 Added 5 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2020-04-06 14:57:58.215 HD Request # 39 | Completion time: 0s | 2020-04-06 14:57:58.216 HD Request # 39 | Intraday data download complete for NISS-NYSE. Unique request ID: 39 | 2020-04-06 14:57:58.216 Removing historical data download ID 39. | 2020-04-06 14:57:58.216 Real-time Intraday chart data file updates started for NISS-NYSE | 2020-04-06 14:57:58.216 Intraday chart data file opened for NISS-NYSE | 2020-04-06 14:57:58.216 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2020-04-06 14:57:58.216 TICK-NYSE [CBV-D][M] 2 Min #39 | Historical data download for additional symbol NISS-NYSE with ID 39 has completed. | 2020-04-06 14:57:58.216 Triggering next historical data download in queue. | 2020-04-06 14:57:58.216 HD Request # 40 | Downloading Intraday chart data for RTYM20 to the file RTYM20.scid. Service: cme | 2020-04-06 14:57:58.216 HD Request # 40 | Download start date-time: 2020-04-06 14:57:33.000 | 2020-04-06 14:57:58.216 HD Request # 40 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2020-04-06 14:57:58.216 Socket (4) | Creating socket. | 2020-04-06 14:57:58.216 Socket (4) | Connecting to IP: 8.18.161.133. | 2020-04-06 14:57:58.216 Opened cached Intraday file: C:\SierraChart\Data\ESM20.scid. Thread ID: 21784 | 2020-04-06 14:57:58.274 Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid. Thread ID: 21784 | 2020-04-06 14:57:58.274 HD Request # 40 | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:58.285 HD Request # 40 | Sending historical data logon request message. | 2020-04-06 14:57:58.285 HD Request # 40 | Requesting Intraday data. Start date-time: 2020-04-06 14:57:33. Record interval: 0. Symbol: RTYM20 | 2020-04-06 14:57:58.313 HD Request # 40 | Decompressing data. | 2020-04-06 14:57:58.342 HD Request # 40 | Receiving Intraday data for RTYM20 starting at 2020-04-06 14:57:33 | 2020-04-06 14:57:58.343 Socket (4) | CloseSocket call. | 2020-04-06 14:57:58.343 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:58.343 Socket (4) | Socket gracefully closed by remote side. | 2020-04-06 14:57:58.379 Socket (4) | Closed. | 2020-04-06 14:57:58.379 Historical data download thread signaled to stop. | 2020-04-06 14:57:58.392 HD Request # 40 | Timestamp of first Intraday data file record written: 2020-04-06 14:57:33 | 2020-04-06 14:57:58.392 HD Request # 40 | Received 43 records from 2020-04-06 14:57:33.000 to 2020-04-06 14:57:56.006 (23.0 seconds) and wrote 42 records for RTYM20 | 2020-04-06 14:57:58.393 HD Request # 40 | Completion time: 0s | 2020-04-06 14:57:58.394 HD Request # 40 | Intraday data download complete for RTYM20. Unique request ID: 40 | 2020-04-06 14:57:58.394 Removing historical data download ID 40. | 2020-04-06 14:57:58.394 Real-time Intraday chart data file updates started for RTYM20 | 2020-04-06 14:57:58.394 Intraday chart data file opened for RTYM20 | 2020-04-06 14:57:58.394 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2020-04-06 14:57:58.394 Triggering next historical data download in queue. | 2020-04-06 14:57:58.394 HD Request # 41 | Downloading Intraday chart data for NQM20 to the file NQM20.scid. Service: cme | 2020-04-06 14:57:58.394 HD Request # 41 | Download start date-time: 2020-04-06 14:57:33.000 | 2020-04-06 14:57:58.395 HD Request # 41 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2020-04-06 14:57:58.395 Socket (4) | Creating socket. | 2020-04-06 14:57:58.395 Socket (4) | Connecting to IP: 8.18.161.135. | 2020-04-06 14:57:58.395 HD Request # 41 | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:58.467 HD Request # 41 | Sending historical data logon request message. | 2020-04-06 14:57:58.467 HD Request # 41 | Requesting Intraday data. Start date-time: 2020-04-06 14:57:33. Record interval: 0. Symbol: NQM20 | 2020-04-06 14:57:58.498 HD Request # 41 | Decompressing data. | 2020-04-06 14:57:58.528 HD Request # 41 | Receiving Intraday data for NQM20 starting at 2020-04-06 14:57:33 | 2020-04-06 14:57:58.528 Socket (4) | CloseSocket call. | 2020-04-06 14:57:58.529 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:58.529 Historical data download thread signaled to stop. | 2020-04-06 14:57:58.536 HD Request # 41 | Timestamp of first Intraday data file record written: 2020-04-06 14:57:34 | 2020-04-06 14:57:58.536 HD Request # 41 | Received 164 records from 2020-04-06 14:57:33.000 to 2020-04-06 14:57:54.000 (21.0 seconds) and wrote 163 records for NQM20 | 2020-04-06 14:57:58.536 Added 24 Time and Sales records to Intraday data file for NQM20 after download. | 2020-04-06 14:57:58.537 HD Request # 41 | Completion time: 0s | 2020-04-06 14:57:58.537 HD Request # 41 | Intraday data download complete for NQM20. Unique request ID: 41 | 2020-04-06 14:57:58.537 Removing historical data download ID 41. | 2020-04-06 14:57:58.537 Real-time Intraday chart data file updates started for NQM20 | 2020-04-06 14:57:58.537 Intraday chart data file opened for NQM20 | 2020-04-06 14:57:58.537 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2020-04-06 14:57:58.537 Triggering next historical data download in queue. | 2020-04-06 14:57:58.537 HD Request # 42 | Downloading Intraday chart data for TICK-NYSE to the file TICK-NYSE.scid. Service: statscalc | 2020-04-06 14:57:58.537 HD Request # 42 | Download start date-time: 2020-04-06 14:57:33.000 | 2020-04-06 14:57:58.538 HD Request # 42 | Using server: ds3.sierracharts.com port 10149 | 2020-04-06 14:57:58.538 Socket (5) | Creating socket. | 2020-04-06 14:57:58.538 Socket (5) | Connecting to IP: 65.182.172.42. | 2020-04-06 14:57:58.538 Socket (4) | Socket gracefully closed by remote side. | 2020-04-06 14:57:58.558 Socket (4) | Closed. | 2020-04-06 14:57:58.558 HD Request # 42 | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:58.611 HD Request # 42 | Sending historical data logon request message. | 2020-04-06 14:57:58.611 HD Request # 42 | Requesting Intraday data. Start date-time: 2020-04-06 14:57:33. Record interval: 0. Symbol: TICK-NYSE | 2020-04-06 14:57:58.641 Chart #37 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.667 Chart #37 has tagged chart #24 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.667 HD Request # 42 | Decompressing data. | 2020-04-06 14:57:58.670 HD Request # 42 | Receiving Intraday data for TICK-NYSE starting at 2020-04-06 14:57:33 | 2020-04-06 14:57:58.671 Socket (5) | CloseSocket call. | 2020-04-06 14:57:58.671 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:58.671 Historical data download thread signaled to stop. | 2020-04-06 14:57:58.678 HD Request # 42 | Timestamp of first Intraday data file record written: 2020-04-06 14:57:34 | 2020-04-06 14:57:58.678 HD Request # 42 | Received 24 records from 2020-04-06 14:57:33.000 to 2020-04-06 14:57:56.000 (23.0 seconds) and wrote 23 records for TICK-NYSE | 2020-04-06 14:57:58.678 Added 25 Time and Sales records to Intraday data file for TICK-NYSE after download. | 2020-04-06 14:57:58.679 HD Request # 42 | Completion time: 0s | 2020-04-06 14:57:58.679 HD Request # 42 | Intraday data download complete for TICK-NYSE. Unique request ID: 42 | 2020-04-06 14:57:58.679 Removing historical data download ID 42. | 2020-04-06 14:57:58.679 Real-time Intraday chart data file updates started for TICK-NYSE | 2020-04-06 14:57:58.679 Intraday chart data file opened for TICK-NYSE | 2020-04-06 14:57:58.679 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2020-04-06 14:57:58.679 Triggering next historical data download in queue. | 2020-04-06 14:57:58.679 HD Request # 43 | Downloading Intraday chart data for YMM20 to the file YMM20.scid. Service: cbot | 2020-04-06 14:57:58.679 HD Request # 43 | Download start date-time: 2020-04-06 14:57:32.000 | 2020-04-06 14:57:58.680 HD Request # 43 | Using server: exchangehistdata2.sierracharts.com port 10150 | 2020-04-06 14:57:58.680 Socket (4) | Creating socket. | 2020-04-06 14:57:58.680 Socket (4) | Connecting to IP: 8.18.161.133. | 2020-04-06 14:57:58.680 Socket (5) | Socket gracefully closed by remote side. | 2020-04-06 14:57:58.700 Socket (5) | Closed. | 2020-04-06 14:57:58.700 HD Request # 43 | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:58.748 HD Request # 43 | Sending historical data logon request message. | 2020-04-06 14:57:58.748 HD Request # 43 | Requesting Intraday data. Start date-time: 2020-04-06 14:57:32. Record interval: 0. Symbol: YMM20 | 2020-04-06 14:57:58.782 Chart #59 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.792 Chart #16 has tagged chart #5 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.802 Chart #16 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.802 HD Request # 43 | Decompressing data. | 2020-04-06 14:57:58.811 HD Request # 43 | Receiving Intraday data for YMM20 starting at 2020-04-06 14:57:32 | 2020-04-06 14:57:58.811 Socket (4) | CloseSocket call. | 2020-04-06 14:57:58.812 Socket (4) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:58.812 Historical data download thread signaled to stop. | 2020-04-06 14:57:58.813 HD Request # 43 | Timestamp of first Intraday data file record written: 2020-04-06 14:57:33 | 2020-04-06 14:57:58.813 HD Request # 43 | Received 113 records from 2020-04-06 14:57:32.000 to 2020-04-06 14:57:56.008 (24.0 seconds) and wrote 110 records for YMM20 | 2020-04-06 14:57:58.813 Added 1 Time and Sales records to Intraday data file for YMM20 after download. | 2020-04-06 14:57:58.814 HD Request # 43 | Completion time: 0s | 2020-04-06 14:57:58.814 HD Request # 43 | Intraday data download complete for YMM20. Unique request ID: 43 | 2020-04-06 14:57:58.814 Removing historical data download ID 43. | 2020-04-06 14:57:58.814 Real-time Intraday chart data file updates started for YMM20 | 2020-04-06 14:57:58.814 Intraday chart data file opened for YMM20 | 2020-04-06 14:57:58.814 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2020-04-06 14:57:58.814 Triggering next historical data download in queue. | 2020-04-06 14:57:58.814 HD Request # 44 | Downloading Intraday chart data for ZBM20 to the file ZBM20.scid. Service: cbot | 2020-04-06 14:57:58.814 HD Request # 44 | Download start date-time: 2020-04-06 14:57:32.000 | 2020-04-06 14:57:58.815 HD Request # 44 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2020-04-06 14:57:58.815 Socket (5) | Creating socket. | 2020-04-06 14:57:58.815 Socket (5) | Connecting to IP: 8.18.161.135. | 2020-04-06 14:57:58.815 Socket (4) | Socket gracefully closed by remote side. | 2020-04-06 14:57:58.840 Socket (4) | Closed. | 2020-04-06 14:57:58.840 Chart #13 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.873 Chart #13 has tagged chart #2 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.873 Chart #13 has tagged chart #49 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.873 HD Request # 44 | Setting DTC encoding to Binary VLS | 2020-04-06 14:57:58.887 HD Request # 44 | Sending historical data logon request message. | 2020-04-06 14:57:58.888 Chart #21 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.915 Chart #21 has tagged chart #9 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.915 HD Request # 44 | Requesting Intraday data. Start date-time: 2020-04-06 14:57:32. Record interval: 0. Symbol: ZBM20 | 2020-04-06 14:57:58.915 Chart #62 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.921 RTYM20 [CBV][M] 1 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:58.926 HD Request # 44 | Decompressing data. | 2020-04-06 14:57:58.945 HD Request # 44 | Receiving Intraday data for ZBM20 starting at 2020-04-06 14:57:32 | 2020-04-06 14:57:58.945 Socket (5) | CloseSocket call. | 2020-04-06 14:57:58.946 Socket (5) | Shutdown started. Waiting for graceful close. | 2020-04-06 14:57:58.946 Socket (5) | Socket gracefully closed by remote side. | 2020-04-06 14:57:58.976 Socket (5) | Closed. | 2020-04-06 14:57:58.976 Historical data download thread signaled to stop. | 2020-04-06 14:57:59.220 HD Request # 44 | Timestamp of first Intraday data file record written: 2020-04-06 14:57:35 | 2020-04-06 14:57:59.220 HD Request # 44 | Received 184 records from 2020-04-06 14:57:32.000 to 2020-04-06 14:57:57.000 (25.0 seconds) and wrote 183 records for ZBM20 | 2020-04-06 14:57:59.220 Added 54 Time and Sales records to Intraday data file for ZBM20 after download. | 2020-04-06 14:57:59.221 HD Request # 44 | Completion time: 0s | 2020-04-06 14:57:59.221 HD Request # 44 | Intraday data download complete for ZBM20. Unique request ID: 44 | 2020-04-06 14:57:59.221 Removing historical data download ID 44. | 2020-04-06 14:57:59.221 Real-time Intraday chart data file updates started for ZBM20 | 2020-04-06 14:57:59.221 Intraday chart data file opened for ZBM20 | 2020-04-06 14:57:59.221 HD Request # 44 | Enabling Intraday chart updating for symbol. | 2020-04-06 14:57:59.221 Triggering next historical data download in queue. | 2020-04-06 14:57:59.221 Chart #14 has tagged chart #1 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.245 Chart #14 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.245 Chart #14 has tagged chart #71 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.245 RTYM20 [CBV][M] 5 Min #24 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.251 Chart #24 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.252 Chart #24 has tagged chart #13 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.252 Chart #24 has tagged chart #2 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.252 Chart #24 has tagged chart #49 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.252 Chart #50 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.266 Chart #20 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.283 Chart #28 has tagged chart #16 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.289 Chart #28 has tagged chart #5 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.289 Chart #28 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.289 RTYM20 [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.307 Chart #2 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.308 Chart #2 has tagged chart #49 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.308 Chart #57 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.332 NQM20 [CBV][M] 5 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.419 Chart #9 has tagged chart #16 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.426 Chart #9 has tagged chart #28 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.426 Chart #9 has tagged chart #5 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.426 Chart #9 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.426 Chart #48 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.437 NQM20 [CBV][M] 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.450 NQM20 [CBV][M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:57:59.463 Chart #35 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.200 Chart #35 has tagged chart #8 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.200 YMM20 [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.213 Chart #1 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.214 Chart #1 has tagged chart #71 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.214 Chart #53 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.225 YMM20 [CBV][M] 5 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.245 Chart #8 has tagged chart #1 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.247 Chart #8 has tagged chart #14 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.247 Chart #8 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.247 Chart #8 has tagged chart #60 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.247 Chart #8 has tagged chart #71 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.247 YMM20 [CBV][M] 1 Min #60 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.271 Chart #60 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.274 Chart #56 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.287 YMM20 [CBV][M] 1 Min #71 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.314 NQM20 [CBV][M] 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.326 Chart #16 has tagged chart #5 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.327 Chart #16 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.327 RTYM20 [CBV][M] 1 Min #49 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.337 RTYM20 [CBV][M] 15 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.356 Chart #13 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.357 Chart #13 has tagged chart #2 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.357 Chart #13 has tagged chart #49 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.357 YMM20 [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.363 RTYM20 [CBV][M] 1 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:00.912 YMM20 [CBV][M] 15 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.233 Chart #14 has tagged chart #1 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.234 Chart #14 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.234 Chart #14 has tagged chart #71 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.234 NQM20 [CBV][M] 15 Min #28 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.281 Chart #28 has tagged chart #16 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.282 Chart #28 has tagged chart #5 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.282 Chart #28 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.282 RTYM20 [CBV][M] 5 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.297 Chart #2 has tagged chart #10 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.298 Chart #2 has tagged chart #49 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.298 NQM20 [CBV][M] 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.437 NQM20 [CBV][M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:01.447 YMM20 [CBV][M] 5 Min #1 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.193 Chart #1 has tagged chart #4 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.195 Chart #1 has tagged chart #71 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.195 YMM20 [CBV][M] 1 Min #71 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.290 NQM20 [CBV][M] 5 Min #16 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.302 Chart #16 has tagged chart #5 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.303 Chart #16 has tagged chart #6 for full recalculation. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.303 RTYM20 [CBV][M] 1 Min #49 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.313 YMM20 [CBV][M] 1 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.339 RTYM20 [CBV][M] 1 Min #10 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:02.889 Opened cached Intraday file: C:\SierraChart\Data\RTYM20.scid. Thread ID: 21784 | 2020-04-06 14:58:03.344 Opened cached Intraday file: C:\SierraChart\Data\NQM20.scid. Thread ID: 21784 | 2020-04-06 14:58:03.344 Opened cached Intraday file: C:\SierraChart\Data\TICK-NYSE.scid. Thread ID: 21784 | 2020-04-06 14:58:03.345 Opened cached Intraday file: C:\SierraChart\Data\YMM20.scid. Thread ID: 21784 | 2020-04-06 14:58:03.345 Opened cached Intraday file: C:\SierraChart\Data\ZBM20.scid. Thread ID: 21784 | 2020-04-06 14:58:03.346 NQM20 [CBV][M] 1 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:03.526 NQM20 [CBV][M] 1 Min #6 | Performing a full recalculation because it has been tagged. Chartbook: IMDivADR Ver 72UR.Cht | 2020-04-06 14:58:03.537 |
[2020-04-07 19:23:59] |
This Message Log looks correct.
[2020-04-07 19:40:06] |
SC Support - Posts: 1927 |
Hi RMos22, for the purpose of getting you onto the Denali Data Feed which replaces the Sierra Chart Exchange Data Feed for CME group data, at the next opportunity, please complete these Market Data Agreements here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements Documentation for Denali: Denali Exchange Data Feed Date Time Of Last Edit: 2020-04-07 23:07:32
[2020-04-14 13:12:09] |
Does Denali include NYSE-TICK and AD line?
[2020-04-15 15:09:24] |
John - SC Support - Posts: 37769 |
This is part of the Sierra Chart Market Statistics which are included with all service packages. Refer to the information here: Real-Time Data: What Real-Time Data is Directly Included with the Service Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-15 18:18:05] |
Refer to the Market Statistics page here: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-20 21:06:45] |
I have completed the Market Data Agreements, when do you plan to switch me over to Denali? Will the instrument symbols and Data/Trade Service Settings remain the same? Is there anything else I need to do on my platform after the switch? |
[2020-04-21 23:33:29] |
We will set this up for you today. You do not need to change the symbols. There are no changes needed but you do need to connect Sierra Chart to your funded trading account as explained here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-21 23:33:59
[2020-04-21 23:44:24] |
@RMos22 The agreement has been rejected: Missing Futures Trading Account Information Please redo the agreements and let us know when done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-21 23:44:34
[2020-04-22 20:25:19] |
Done.
[2020-04-23 02:30:43] |
Sierra Chart - Max - Posts: 5787 |
We have transferred you over to the Denali Data Feed.
Sierra Chart Support |
