Date/Time: Tue, 30 Jun 2026 22:11:48 +0000
ACSIL Currency conversion
View Count: 1277
[2020-04-05 12:45:40]
ACWalker - Posts: 6
I am working on a position sizer, and I would like to be able to convert an account balance in a currency to the currency relevant to the chart.
I suspect the ConvertCurrencyValueToCommonCurrency() function could do this, but I can't seem to get it to work.
For example, for an account balance in GBP on a EURUSD chart I am calling it like this:
SCString outputCurrency;
SCString sourceCurrency = "GBP";
float currency = sc.ConvertCurrencyValueToCommonCurrency(Input_AccountBalance.GetFloat(), sourceCurrency, outputCurrency);
However, the returned currency value is the same value as the inputted currency and the outputCurrency is an empty string. Am I calling the function wrong?
Thanks,
Alex
[2020-04-05 13:18:55]
ForgivingComputers.com - Posts: 1231
If your account is in GBP (output currency), and the chart symbol is EURUSD (source Currency), then try this:
SCString outputCurrency = "GBP";
SCString sourceCurrency = "EURUSD";
Date Time Of Last Edit: 2020-04-05 13:19:09
[2020-04-05 14:34:08]
ACWalker - Posts: 6
Thanks for your reply,
I have tried it as you mentioned, but unfortunately still getting the same result. I'm using a value now for the example, and the currency value being returned is 500.
  SCString outputCurrency = "EURUSD";
  float currency = sc.ConvertCurrencyValueToCommonCurrency(500.0f, sourceCurrency, outputCurrency);
[2020-04-05 16:32:26]
User907968 - Posts: 873
Did you set the 'Common Profit/Loss Currency' to GBP?
Global Trade Settings Windows: Common Profit/Loss Currency (Global Settings >> General Trade Settings >> General)
[2020-04-12 01:33:01]
You have the second parameter wrong. The second parameter is as follows:
const SCString& SourceSymbol
It needs to be set to EURUSD
You also need to set the common currency as explained in post #4. Here is the updated documentation:
ACSIL Interface Members - Functions: sc.ConvertCurrencyValueToCommonCurrency()
Date Time Of Last Edit: 2020-04-12 01:35:14
