Date/Time: Mon, 28 Sep 2026 14:59:21 +0000
Order routing
View Count: 897
| [2020-04-05 05:27:11] |
| User575399 - Posts: 350 |
I currently use GAIN , but I’m thinking of switching to Sierra order routing . What are the total fees(monthly?)for using order execution through SC instead ?
| [2020-04-05 14:05:11] |
| SKZ90 - Posts: 74 |
https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#FAQ_WhyDoYouChargePerContractForOrderRouting ^^ specific answer but the whole page is relevant to your question. |
| [2020-04-06 15:32:41] |
| John - SC Support - Posts: 48030 |
There are no monthly fees specific to the Order Routing service from us (Sierra Chart). There is just the cost for Sierra Chart and for any Real-Time data that you need, to which you are already paying for (Denali Exchange Data Feed). However, the cost of the data feed goes down from 25 a month to 20 USD a-month. You can change that option here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed For any other fees, you would need to ask the broker that you use for the Order Routing service. You can find a list of brokers at Step #2 at this link: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-06 18:59:15
| [2020-04-06 18:42:48] |
There is going to be a .10 transaction fee per contract per side: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#FAQ_WhyDoYouChargePerContractForOrderRouting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
