Date/Time: Wed, 05 Feb 2025 23:11:26 +0000
DTC Server - Invalid certificate
View Count: 554
[2020-04-05 02:23:01] |
User442651 - Posts: 25 |
I am trying to connect to the DTC Server with a TLS TCP/IP Socket connection, using .NET (C#). When I try to authenticate the SslStream it throws the exception: The remote certificate is invalid according to the validation procedure. In the Web Socket Connections section of the documentation it is stated that "When connecting to the DTC Protocol Server in Sierra Chart using a websocket connection from a web browser, it is necessary to install a valid TLS certificate for the domain used." Is this also necessary for a TCP/IP connection? |
[2020-04-05 05:05:28] |
If you want to use TLS and the client-side is doing certificate validation, then the answer is yes. We think it would be best to disable certificate validation.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-05 05:06:08
