Date/Time: Wed, 05 Feb 2025 22:42:45 +0000
stop attached orders from moving with the parent price
View Count: 706
[2020-04-04 02:37:42] |
User658985 - Posts: 30 |
in ascil im creating a trade with some attached orders (stop, couple of targets). when i move the price of the parent order, the attached orders all move with it. how do i stop this behavior? im using ascil to create and modify the orders.
[2020-04-04 07:47:36] |
There is not a way to change this.
[2020-04-04 09:43:23] |
thats surprising. mm ok so if wanted to work around this, would i first need to send an order to change the price of of the parent, then change the price of each attached order? or is there a more efficient way of doing this?
[2020-04-06 11:09:20] |
Yes you would have to modify the Attached Orders programmatically using ACSIL, when modifying the parent order.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-06 11:09:30
