Date/Time: Sun, 16 Mar 2025 08:28:52 +0000
Feature Request: Telegram Integration
View Count: 1447
[2020-04-03 21:32:09] |
User686651 - Posts: 1 |
Hi there, New to your application now for a few months and love it. I'm looking to do some automation that requires reading of alerts generated. Not overly keen on using email due to it being slower an unreliable. I've looked into using Twitter however they have some strong restrictions on accounts and developer accounts which isn't ideal. Telegram is the automate app for this kinda stuff these days. Do you have any plans to build an alert integration with Telegram or so I need to suck it up and use email? |
[2020-04-04 07:48:58] |
No but you can look into doing your own integration with Telegram from an ACSIL study. Have a look at this function: ACSIL Interface Members - Functions: sc.MakeHTTPRequest() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-04 07:50:11
[2022-08-11 07:19:36] |
User275592 - Posts: 97 |
you can use "no code" applications to forward the email alert sent by Sierrachart to your telegram account
