Date/Time: Sat, 04 May 2024 00:39:14 +0000
Sierra Chart RT Data TT Fix
View Count: 616
[2020-04-03 19:12:16] |
User696767 - Posts: 6 |
Hi! My data is delayed 10 min. I gave instructios to AMP to subscribe Sierra Chart RT Data TT Fix. Whats Wrong with my data? Ty |
[2020-04-03 20:06:21] |
AMP has already solved it. They hadn't subscribed to me. But I now have the problem that my Denali data is approximately 2 minutes late. I compare it to Ninja and CQG data and the delay is significant.What could it be? I need help with that please. |
Attachment Deleted. Screenshot at Apr 03 15-58-53.png / V - Attached On 2020-04-03 20:06:09 UTC - Size: 699.71 KB - 216 views |
[2020-04-03 20:42:03] |
We want you to review this subtopic and try the items described to see if the problem is resolved: Prices / Data Falling Behind: 4.12 - Sierra Chart Exchange Data Feeds Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-07 04:20:24] |
Hi John, I need your help, my data suffers in some hours of the day delays of up to 20 seconds, while I notice how the CQG and Ninja run smoothly and without interruptions, I use Sierra and Ninja at the same time and in the same computer. I thought that by switching to Sierra with Denali I wouldn't have any problems about that. This has kept me from trading these last two days at Regular Hours which is when I trade my system. I tried the recommendations you gave me in the link, such as lowering levels in market depth, I totally disabled the windows firewall, which was the only one active. I need to get support on this please.
Screenshot at Apr 06 15-03-23.png / V - Attached On 2020-04-07 04:12:21 UTC - Size: 133.4 KB - 195 views Screenshot at Apr 06 14-57-12.png / V - Attached On 2020-04-07 04:13:27 UTC - Size: 149.95 KB - 193 views Screenshot at Apr 06 15-09-23.png / V - Attached On 2020-04-07 04:14:38 UTC - Size: 173.02 KB - 191 views |
[2020-04-07 07:50:20] |
. I thought that by switching to Sierra with Denali I wouldn't have any problems about that. No that is not necessarily true. We have no control over the public Internet or your connectivity.It depends upon the amount of bandwidth usage and possibly also on the port. This is not related to a firewall. We want you to enable low bandwidth mode: Real-Time Exchange Data Feeds Available From Sierra Chart: Low Bandwidth Option And we want you to enable the option for port 443: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#AlwaysUsePort443 Be sure to reconnect after enabling these options. The other possibility would be to run Sierra Chart on a server, like a virtual private server somewhere in the US, and then you connect to it with remote desktop protocol. Please do not provide any further screenshots. They are not helpful. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-07 07:51:43
