Date/Time: Wed, 05 Feb 2025 21:42:58 +0000
sierra is to slow
View Count: 632
[2020-04-03 01:33:25]
AC84142 - Posts: 9
Whenever I open Sierra and make changes in my chart I get following message from the Trade Service Log:
„Trade Activity file unexpected condition. Did not find FIELD-CODE_BEGIN_RECORD when expected. Field code read:0. C:\SierraChart\TradeActivityLogs\TradeActivityLog_2020-03-03UTCdata…………“
Also after update Sierra id to slow
how can i fix and delete this file step by step
thanks
[2020-04-03 19:27:25]
We want you to convert the Trade Activity File format as explained in the notes here for 2050:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2050
Select File >> Disconnect.
Select Global Settings >> Convert Trade Activity Format.
Select File >> Connect to Data Feed.
This procedure only needs to be done once.
If you want to delete that file, just go into the TradeActivityLogs subfolder in the Sierra Chart installation folder with the operating system file manager and then delete that file.
To improve performance, refer to:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.48 - Basic Steps to Resolve Performance Issue in Sierra Chart
Date Time Of Last Edit: 2020-04-03 19:27:57
