Date/Time: Sun, 04 Oct 2026 13:09:45 +0000
[User Discussion] - Color Bar Based on Alert
View Count: 2789
[2020-04-03 01:09:51]
toews&kane - Posts: 209
So I am using this study and looking at Volume/NumberTrades alert >=X to color a bar realtime and have it stayed colored
(i.e this ratio will fluctuate up and down according to the time period set, close can be <X but at any point I want it colored if condition NumTrades>= x hits)
The alert itself is working because I am outputting it to alert manager.
However, the coloring of a bar does not work, even when I have evaluate on bar close unchecked.
Please advise.
Need this one will save me a lot of time trying to make things down manually.
Cheers,
W
[2020-04-03 23:00:54]
bump
[2020-04-04 04:33:01]
Sawtooth - Posts: 4355
This formula alerts and colors the bars:
=V/NT>1.5
What formula are you using?
[2020-04-06 05:02:37]
I am not using the spread sheet, I am just using that study volume/numtrades, I think it returns a whole number so I don't think it's catching the decimal correct me if I am wrong.
I went V/NT>= 3
Sometimes it will spike to 3, but close at say 2.
Cheers
[2020-04-06 12:11:23]
What you want to do is not possible with Simple Alerts or a spreadsheet study.
Capturing an intrabar event and making it persistent can only be done with a custom ACSIL study.
Maybe user @Ackin can help you.
[2020-04-06 13:02:02]
Ackin - Posts: 1865
toews&kane)
When the graph is running I can (Replay, Sim, Live). I won't make it in history.
If you want it - you can register in our forum, this study will be in the next update.
contact link:
Date Time Of Last Edit: 2020-04-06 13:02:31
[2020-04-07 20:29:02]
Ackin - Posts: 1865
It's done.
Study name: Max (Vol/Trade) Colorbar
contact link:
imageMax vol num trades colorbar.png / V - Attached On 2020-04-07 20:28:38 UTC - Size: 13.95 KB - 659 views
[2020-04-07 21:38:05]
how can I register, this is amazing if I can get this to work
[2020-04-07 21:42:33]
Ackin - Posts: 1865
Everything is described here:
After registration you will only be asked to send SC Account, which I put into the form Sierrachart to set up user rights to the library.
Over 400 people have done it, it's not hard ...
[2020-04-07 21:48:19]
Ackin - Posts: 1865
btw.
I also made a version where you can see the progress in the region
if you want some modification in it then write me directly into the forum to the study, these are 20 minute projects, I do not know the specific needs of each user, just I make a universal and easy solution.
imageMax vol num trades.png / V - Attached On 2020-04-07 21:43:41 UTC - Size: 9.39 KB - 600 views
[2020-04-07 21:51:09]
On your forum page, there's no registration link that I can find
[2020-04-07 21:54:53]
Ackin - Posts: 1865
https://forum.obchodni-indikatory.cz/contact-us
or email: zyp.sierra@gmail.com
Date Time Of Last Edit: 2020-04-07 22:03:10
