Date/Time: Wed, 05 Feb 2025 22:02:46 +0000
Is Denali able to feed SC Order Routing and Rithmic on the same workstation?
View Count: 701
[2020-04-02 23:47:55] |
User695518 - Posts: 53 |
Hello Support, I have been using Denali to feed both an SC Order Routing account and Rithmic order routing on the same workstation. I am running separate installations of SC for each data service. This has been working great for many months. However, I understand there are new limitations on simultaneous data feed connections. As of today, I am now seeing this in the message log: SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2020-04-02 16:52:58.897 However, from the following post, it seems that I should be allowed additional connections from the same workstation: Notice: CME Fees Price Increase / Denali Exchange Data Feed Connection Management Denali Exchange Data Feed clients will now be allowed up to 3 connections on the same system but there is a limit to the number of simultaneous systems for the Denali Exchange Data Feed of 1. How can I resolve this limitation? Is there any way that the DTC server and Denali can feed both SC Order Routing and Rithmic on the same workstation? I previously attempted such a configuration in this thread, but was unsuccessful: Denali data with multiple copies of SC Thanks! Date Time Of Last Edit: 2020-04-02 23:57:03
[2020-04-02 23:59:47] |
Looks like the answer is to upgrade to SC 2072 or later? Does this version require recompiling DLLs? I am currently running SC 2060 and 2057.
Date Time Of Last Edit: 2020-04-03 00:00:35
[2020-04-03 01:18:00] |
Yes you just need to update. If you update you can then use 3 connections on the same system. Update instructions: Software Download: Fast Update A recompile of custom studies should not be necessary. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
