Date/Time: Wed, 05 Feb 2025 23:07:45 +0000
[User Discussion] - LMAX
View Count: 652
[2020-04-02 23:12:33]
tradingest - Posts: 4
How can I see the latency LMAX using Sierra platform?
[2020-04-04 10:00:37]
You really just have to do actual live trading testing and then check the timestamps in the Trade >> Trade Activity Log.
[2020-04-04 11:45:43]
The difference between Order and Fill row is 001. That means 1/100 sec?
If not so, can you help me to understand the latency from the image below?
thanks in advance
imageLatency.jpg / V - Attached On 2020-04-04 11:44:12 UTC - Size: 24.96 KB - 243 views
[2020-04-04 11:48:36]
That is simulated trading and is meaningless.
[2020-04-04 13:19:09]
I wanted to understand if the meaning of the lines I analyzed is correct.
Difference time between Order and Filled row. Right?
[2020-04-04 21:23:06]
ForgivingComputers.com - Posts: 994
No. The Difference in the attached picture is 0.001 seconds = 1 millisecond = 1/1000th of a second.
