Date/Time: Wed, 05 Feb 2025 23:06:28 +0000
Screenshot API
View Count: 880
[2020-04-02 22:34:21]
User617678 - Posts: 8
Is there any API to save screenshots of a chart?
Thank you
[2020-04-02 23:09:06]
I found the API call inside sierrachart.h
[2020-04-05 14:46:05]
User701453 - Posts: 176
I created a function:
void ScreenShotTaker(SCStudyInterfaceRef sc)
sc.SaveChartImageToFile = 1;
Created an input in my strat named "Enable_TradeEntryScreenShot".
Then place the below code when the entry order was called.
//TAKE A SCREEN SHOT
if (Enable_TradeEntryScreenShot.GetYesNo())
   ScreenShotTaker(sc);
Date Time Of Last Edit: 2020-04-05 14:47:17
[2020-04-05 15:07:54]
I started using this sc.SaveChartImageToFileExtended() since it provides more customization.
Thank you very much for your reply.
Kind regards
