Date/Time: Mon, 25 Nov 2024 04:51:13 +0000
Order entry issue
View Count: 1070
[2014-01-13 09:13:39] |
RLH1 - Posts: 2 |
Good morning, When trying to place an order in FGBL this morning I receive the following error message: "Trade Order Error - TT order update (Rejected). Info: From Gateway: No currency conversion exists. Internal Order ID: 9984. Service Order ID: 0G8KG1218. Symbol: FGBL-201403-Eurex | 2014-01-13 04:10:32" This is the first time this has happened. Is this a software issue or an issue at my broker? Thank you! RLH - |
[2014-01-13 09:20:09] |
Please contact your broker about this.
