Date/Time: Wed, 05 Feb 2025 21:53:46 +0000
Virus
View Count: 501
[2020-04-02 19:12:42] |
denniz901 - Posts: 1 |
Hello, i got an window popping up when i open your application. And your application are giving me this message: "The Configuration file size of 0 byes is not the 416799 expected bytes to write. The configuration file might be corrupt" What should i do? |
[2020-04-02 19:32:23] |
i got an window popping up when i open your application. Can you attach a screenshot of that window you see.
