Date/Time: Wed, 05 Feb 2025 22:59:25 +0000
Move to breakeven for stop
View Count: 1365
[2020-04-02 19:01:59] |
FuturesDT-Matt - Posts: 3 |
Hi- would like to know what is the best option for me. I have 4 targets and 4 stops. I would like all my stops moved to break even once my first target is triggered at +4. What should I set my "move to breakeven for stop", what type?? Thanks for help anyone
[2020-04-04 11:17:34] |
Are all of the stops at different prices? Or are they the same price? Basically you would configure the Move to Breakeven for Stop settings for each stop as shown here: Attached Orders: 2 Targets and Common Stop with Move to Breakeven on First Target Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
