Date/Time: Wed, 05 Feb 2025 21:48:42 +0000
[User Discussion] - Server Side Orders TT Fix
View Count: 519
[2020-04-02 17:14:37] |
User642546 - Posts: 1 |
Hello SC team. Can you help me please? I don't find a satisfactory answer to my question in the documentary. What happens if I have a bracket order with my account settings and the TT Fix Routing in the market and the electricity or the internet at my home fails? Does the stop take effect if I lose the connection or do I have a position without a stop in the market? I have activated Server Side Bracket and Server Side OCO Orders. Best Regards Marcus |
[2020-04-02 17:54:20] |
Does the stop take effect if I lose the connection Yes when you are using Server-side Bracket Orders.
