Date/Time: Wed, 05 Feb 2025 21:52:05 +0000
using the denali feed with a tradovate account
View Count: 1363
[2020-04-02 14:38:10] |
adam czuk - Posts: 26 |
I only want to use the denali data feed for charting. I don't need to integrate my broker (tradovate) with sierra for order routing. I just want Denali's real time data purely for charting purposes. For the denali package labeled: "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts" It says a trading account is required. However, on this page: (Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services) it does not list Tradovate as a supported service. How do I make this work? Do I have to have Tradovate integrate with CQG and then use that to connect to the denali feed? I have asked before if tradovate is compatible with sierra charts, but I got a confusing answer: "It is supported through CQG" I'm sorry I don't understand what that means or what I need to do to make this work. CQG and tradovate are two separate entities. |
[2020-04-02 19:23:23] |
Do I have to have Tradovate integrate with CQG and then use that to connect to the denali feed? Essentially yes. You do need the CQG account from your broker and then Sierra Chart has to be able to connect to it to authorize the CME data.Or you could follow this solution here: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-02 19:24:19
