Date/Time: Sun, 05 Jul 2026 01:29:01 +0000
Study Subgraph Name&Value labels
View Count: 1267
[2020-04-02 14:26:23]
User156295 - Posts: 105
Hell
Would like to have Study Subgraph Name&Value labels as both centered above/below the line and to see them both.
When I put for both vertical align as "Centered" and horizontal as "Right" for both than the only one label is visible and the other label is hidden behind.
How to set it to have both labels centered above/below the line with the same horizontal Right alignement?
Pls also find here image for this case https://prnt.sc/rrm9pd
[2020-04-02 15:01:07]
John - SC Support - Posts: 47017
We are confused by your statements and then the image that you supplied. The image is showing the way that you need to do this. You need to set one item to Above and the other to Below. Then they will show as they are in the image.
If you set them both to have a Vertical Alignment of Centered, then you will only be able to see one of them.
Refer to the following for more information:
Chart Studies: Subgraphs Tab >> Name and Value Labels
[2020-04-02 15:09:06]
Yes, sorry, image shows how I deal with this now.
Wanted to know that if I would set them both a Vertical Alignment of Centered than I could see both of them close each other
I understand it is impossible to have them both like when drawing a line and I can have both visible text and value on the same horizontal line level.
