Date/Time: Wed, 05 Feb 2025 21:54:53 +0000
Connection to AMP Futures using Sierrachart data feed.
View Count: 3095
[2020-04-02 13:29:50] |
User60854 - Posts: 1 |
Hello, I have contacted AMP futures but they did not know how to connect their brokerage to your platform using your data. Is any chance to help me? Thank you |
[2020-04-02 18:18:53] |
Is your account with AMP using the CQG trading platform service? If so, follow these instructions: CQG Trading Platform Service: Setup Instructions Since you are using the Denali Data Feed, also follow these instructions here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-02 18:19:44
