Date/Time: Wed, 05 Feb 2025 21:45:57 +0000
Historical data logon error: Unsupported protocol version in latest v2074, and v2052
View Count: 645
[2020-04-02 03:25:20] |
uM8137 - Posts: 183 |
Do I need to worry about this "Unsupported protocol" error while pulling data for a continuous contract in ZT?##_FUT_CBOT from Denali? This is on a subinstance, if that matters. Subinstance v2074 connecting to the main instance v2057. It also happened when I ran v2052 as a subinstance. Also, note the "Historical data ZLib Error: incorrect header check" error. Worrisome? message log: Reading Internal Order ID file. | 2020-04-01 22:48:39.657 Reading Trade Orders file. | 2020-04-01 22:48:39.712 Reading Trade Positions file. | 2020-04-01 22:48:39.712 Reading Account Balance file. | 2020-04-01 22:48:39.713 UDPListener (1384). Port 22904 | Listening on UDP port 22904. | 2020-04-01 22:48:39.727 Software version: 2074 64-bit | 2020-04-01 22:48:39.727 Primary Thread ID: 10920 | 2020-04-01 22:48:39.727 Usage end date: 2021-02-24 | 2020-04-01 22:48:39.727 Enabled for: Advanced Features 2. | 2020-04-01 22:48:39.727 Enabled for: Sierra Chart Historical Data Service. | 2020-04-01 22:48:39.727 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2020-04-01 22:48:39.727 Enabled for: Denali Real-Time Exchange Data Feed. | 2020-04-01 22:48:39.727 Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-04-01 22:48:39.727 Enabled for exchange: INDEXES_DATA_BARCHART | 2020-04-01 22:48:39.727 Enabled for exchange: Eurex with Market Depth | 2020-04-01 22:48:39.727 Enabled for exchange: U.S. Equities (NYSE, NASDAQ, AMEX, BATS) | 2020-04-01 22:48:39.727 Enabled for exchange: BATS (NYSE, NASDAQ) | 2020-04-01 22:48:39.727 Enabled for exchange2: CME (Trading Account Required) | 2020-04-01 22:48:39.727 Enabled for exchange2: CBOT (Trading Account Required) | 2020-04-01 22:48:39.727 Enabled for exchange2: COMEX (Trading Account Required) | 2020-04-01 22:48:39.727 Enabled for exchange2: NYMEX (Trading Account Required) | 2020-04-01 22:48:39.727 Received 1 data feed usernames. | 2020-04-01 22:48:39.727 Allow Support for Sierra Chart Data Feeds is enabled. | 2020-04-01 22:48:39.727 Current selected Data/Trading service: DTC - Sub Instance | 2020-04-01 22:48:39.727 Custom symbol settings values: enabled | 2020-04-01 22:48:39.727 Chart Update Interval: 500 | 2020-04-01 22:48:39.727 Intraday Data Storage Time Unit: 0 | 2020-04-01 22:48:39.727 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-04-01 22:48:39.727 2020-04-01 22:48:39 Local computer time | 2020-04-01 22:48:39.727 2020-04-02 02:48:39 Local computer time in UTC | 2020-04-01 22:48:39.727 2020-04-01 22:48:39 Local computer time in SC Time Zone | 2020-04-01 22:48:39.727 2020-04-02 02:48:38 Server time in UTC | 2020-04-01 22:48:39.727 Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-04-01 22:48:39.727 Program path: C:\SierraChart2074\ | 2020-04-01 22:48:39.727 Data Files path: C:\SierraChart2074\Data\ | 2020-04-01 22:48:39.727 OS Version Number: 10.0 | 2020-04-01 22:48:39.728 Locale Setting: C | 2020-04-01 22:48:39.728 DLLs: sst_FreeBundle.dll, sst_FreeBundle_64.dll | 2020-04-01 22:48:39.728 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 22:48:39.764 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-04-01 22:48:39.879 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-04-01 22:48:39.879 Received 5 login tokens. | 2020-04-01 22:48:40.133 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11111 | 2020-04-01 22:48:45.368 DTC Client socket (1) | Creating socket. | 2020-04-01 22:48:45.368 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 22:48:45.368 DTC - Sub Instance | Connected to server. | 2020-04-01 22:48:45.370 DTC - Sub Instance | Starting socket receive thread. | 2020-04-01 22:48:45.370 DTC - Sub Instance | Sending encoding request to server: Binary VLS | 2020-04-01 22:48:45.370 DTC - Sub Instance | Did not receive Encoding Response from server. Disconnecting. | 2020-04-01 22:49:05.368 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2020-04-01 22:49:05.368 Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-01 22:49:05.368 DTC Client socket (1) | CloseSocket call. | 2020-04-01 22:49:05.384 DTC - Sub Instance | Disconnected. | 2020-04-01 22:49:05.384 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2020-04-01 22:49:05.384 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 22:49:05.384 DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11111 | 2020-04-01 22:49:08.393 DTC Client socket (2) | Creating socket. | 2020-04-01 22:49:08.393 DTC Client socket (2) | Connecting to IP: 127.0.0.1. | 2020-04-01 22:49:08.393 DTC - Sub Instance | Connected to server. | 2020-04-01 22:49:08.394 DTC - Sub Instance | Starting socket receive thread. | 2020-04-01 22:49:08.394 DTC - Sub Instance | Sending encoding request to server: Binary VLS | 2020-04-01 22:49:08.394 DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-04-01 22:49:08.891 DTC Client socket (1) | Closed. | 2020-04-01 22:49:08.891 DTC - Sub Instance | Setting DTC encoding to Binary VLS | 2020-04-01 22:49:09.177 DTC - Sub Instance | Sending logon request message. | 2020-04-01 22:49:09.177 DTC - Sub Instance | Received logon response. | 2020-04-01 22:49:09.227 DTC - Sub Instance | Server Name: SC DTC Server. | 2020-04-01 22:49:09.227 DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 | 2020-04-01 22:49:09.227 DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures.dtc.trading|SymbolSettings=sc_futures.dtc.trading. | 2020-04-01 22:49:09.227 DTC - Sub Instance | Trading is not supported. | 2020-04-01 22:49:09.227 DTC - Sub Instance | Connected to data and trading server. | 2020-04-01 22:49:09.227 Triggering next historical data download in queue. | 2020-04-01 22:49:09.227 Triggering next historical data download in queue. | 2020-04-01 22:49:09.227 Triggering next historical data download in queue. | 2020-04-01 22:49:09.227 Triggering next historical data download in queue. | 2020-04-01 22:49:09.227 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures.dtc.trading. Request ID: 1. | 2020-04-01 22:49:09.230 Symbol settings MD5 received. Request ID: 1. | 2020-04-01 22:49:09.855 Symbol settings are up-to-date for sc_futures.dtc.trading. | 2020-04-01 22:49:09.855 ZTH20_FUT_CBOT 1 Min #1 | Reloading chart. | 2020-04-01 22:51:37.508 ZTH20_FUT_CBOT 1 Min #2 | Reloading chart. | 2020-04-01 22:51:37.535 ZTH20_FUT_CBOT 1 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2074\Data\ZTH20_FUT_CBOT.scid | 2020-04-01 22:51:37.545 ZTH20_FUT_CBOT 1 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart2074\Data\ZTH20_FUT_CBOT.scid | 2020-04-01 22:51:37.547 SC Futures Order Routing/Data | Starting real-time market data updates for: ZTH20_FUT_CBOT. ID: 1 | 2020-04-01 22:51:38.014 SC Futures Order Routing/Data | Requesting security definition data for: ZTH20_FUT_CBOT. ID: 1 | 2020-04-01 22:51:38.014 Starting DelayedDownloadMonitoringTimer | 2020-04-01 22:51:38.014 Starting HDTimeoutTimer | 2020-04-01 22:51:38.014 Added historical Intraday data request for ZTH20_FUT_CBOT to the queue. | 2020-04-01 22:51:38.014 Intraday data recording state for symbol ZTH20_FUT_CBOT is set to download 'Pending'. | 2020-04-01 22:51:38.014 Triggering next historical data download in queue. | 2020-04-01 22:51:38.014 Delaying start of download for ZTH20_FUT_CBOT | 2020-04-01 22:51:38.014 SC Futures Order Routing/Data | Received security definition for symbol ZTH20_FUT_CBOT | 2020-04-01 22:51:41.656 HD Request # 1 | Downloading Intraday chart data for ZTH20_FUT_CBOT to the file ZTH20_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 22:51:46.046 HD Request # 1 | Download start date-time: 2012-01-13 18:59:59.000 | 2020-04-01 22:51:46.047 HD Request # 1 | Using server: 127.0.0.1 port 22222 | 2020-04-01 22:51:46.047 Socket (1) | Creating socket. | 2020-04-01 22:51:46.047 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 22:51:46.047 HD Request # 1 | Setting DTC encoding to Binary VLS | 2020-04-01 22:51:53.843 HD Request # 1 | Sending historical data logon request message. | 2020-04-01 22:51:53.843 HD Request # 1 | Requesting Intraday data. Start date-time: 2012-01-13 18:59:59. Record interval: 0. Symbol: ZTH20_FUT_CBOT | 2020-04-01 22:51:56.204 HD Request # 1 | Decompressing data. | 2020-04-01 22:52:01.983 HD Request # 1 | Receiving Intraday data for ZTH20_FUT_CBOT starting at 2019-10-01 04:25:31 | 2020-04-01 22:52:02.030 HD Request # 1 | Timestamp of first Intraday data file record written: 2019-10-01 04:25:31 | 2020-04-01 22:52:02.358 Socket (1) | CloseSocket call. | 2020-04-01 22:56:56.494 Historical data download thread signaled to stop. | 2020-04-01 22:56:56.494 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 22:56:56.494 HD Request # 1 | Received 5136110 records from 2019-10-01 04:25:31.000 to 2020-03-30 09:40:56.001 (181.2 days) and wrote 5136110 records for ZTH20_FUT_CBOT | 2020-04-01 22:56:56.494 HD Request # 1 | Completion time: 5m 10s | 2020-04-01 22:56:56.495 HD Request # 1 | Intraday data download complete for ZTH20_FUT_CBOT. Unique request ID: 1 | 2020-04-01 22:56:56.495 Removing historical data download ID 1. | 2020-04-01 22:56:56.495 Real-time Intraday chart data file updates started for ZTH20_FUT_CBOT | 2020-04-01 22:56:56.495 Intraday chart data file opened for ZTH20_FUT_CBOT | 2020-04-01 22:56:56.495 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2020-04-01 22:56:56.495 Triggering next historical data download in queue. | 2020-04-01 22:56:56.495 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 22:57:02.019 Socket (1) | Closed. | 2020-04-01 22:57:02.019 ZTH20_FUT_CBOT [CV] 1 Min #2 | Reloading chart. | 2020-04-01 22:58:37.713 Added historical Intraday data request for ZTM17_FUT_CBOT to the queue. | 2020-04-01 22:58:37.713 Triggering next historical data download in queue. | 2020-04-01 22:58:37.713 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTM17_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.714 Added historical Daily data request for ZTM17_FUT_CBOT to the queue. | 2020-04-01 22:58:37.714 Added historical Intraday data request for ZTU17_FUT_CBOT to the queue. | 2020-04-01 22:58:37.714 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTU17_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.714 Added historical Daily data request for ZTU17_FUT_CBOT to the queue. | 2020-04-01 22:58:37.714 Added historical Intraday data request for ZTZ17_FUT_CBOT to the queue. | 2020-04-01 22:58:37.715 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTZ17_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.715 Added historical Daily data request for ZTZ17_FUT_CBOT to the queue. | 2020-04-01 22:58:37.715 Added historical Intraday data request for ZTH18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.716 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTH18_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.717 Added historical Daily data request for ZTH18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.717 Added historical Intraday data request for ZTM18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.717 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTM18_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.717 Added historical Daily data request for ZTM18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.717 Added historical Intraday data request for ZTU18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.717 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTU18_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.718 Added historical Daily data request for ZTU18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.718 Added historical Intraday data request for ZTZ18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.718 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTZ18_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.718 Added historical Daily data request for ZTZ18_FUT_CBOT to the queue. | 2020-04-01 22:58:37.718 Added historical Intraday data request for ZTH19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.719 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTH19_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.719 Added historical Daily data request for ZTH19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.719 Added historical Intraday data request for ZTM19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.719 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTM19_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.720 Added historical Daily data request for ZTM19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.720 Added historical Intraday data request for ZTU19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.720 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTU19_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.720 Added historical Daily data request for ZTU19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.721 Added historical Intraday data request for ZTZ19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.721 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTZ19_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.721 Added historical Daily data request for ZTZ19_FUT_CBOT to the queue. | 2020-04-01 22:58:37.721 ZTH20_FUT_CBOT [CV] 1 Min #2 | Performing historical Daily data download for symbol ZTH20_FUT_CBOT starting at last date in file. | 2020-04-01 22:58:37.722 Added historical Daily data request for ZTH20_FUT_CBOT to the queue. | 2020-04-01 22:58:37.722 ZTH20_FUT_CBOT [CV] 1 Min #2 | Waiting for historical downloads to complete with the IDs: 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, | 2020-04-01 22:58:37.724 HD Request # 2 | Downloading Intraday chart data for ZTM17_FUT_CBOT to the file ZTM17_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 22:58:37.769 Compressing file: C:\SierraChart2074\Data\ZTM17_FUT_CBOT.scid. This may take a while. | 2020-04-01 22:58:37.769 HD Request # 2 | Download start date-time: 2017-02-08 19:00:00.000 | 2020-04-01 22:58:37.769 HD Request # 2 | Using server: 127.0.0.1 port 22222 | 2020-04-01 22:58:37.770 Socket (1) | Creating socket. | 2020-04-01 22:58:37.770 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 22:58:37.770 HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-04-01 22:58:41.579 HD Request # 2 | Sending historical data logon request message. | 2020-04-01 22:58:41.579 HD Request # 2 | Requesting Intraday data. Start date-time: 2017-02-08 19:00:00. Record interval: 0. Symbol: ZTM17_FUT_CBOT | 2020-04-01 22:58:43.020 HD Request # 2 | Data is being downloaded from a remote source. Download will start when this is done. | 2020-04-01 22:58:43.240 HD Request # 2 | Decompressing data. | 2020-04-01 22:58:58.239 HD Request # 2 | Receiving Intraday data for ZTM17_FUT_CBOT starting at 2017-02-09 10:41:53 | 2020-04-01 22:58:58.291 HD Request # 2 | Timestamp of first Intraday data file record written: 2017-02-09 10:41:53 | 2020-04-01 22:58:59.396 Socket (1) | CloseSocket call. | 2020-04-01 23:01:33.457 Historical data download thread signaled to stop. | 2020-04-01 23:01:33.458 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:01:33.458 HD Request # 2 | Received 2983596 records from 2017-02-09 10:41:53.000 to 2017-06-30 10:19:32.006 (140.9 days) and wrote 2983596 records for ZTM17_FUT_CBOT | 2020-04-01 23:01:33.458 HD Request # 2 | Completion time: 2m 56s | 2020-04-01 23:01:33.460 HD Request # 2 | Intraday data download complete for ZTM17_FUT_CBOT. Unique request ID: 2 | 2020-04-01 23:01:33.460 Removing historical data download ID 2. | 2020-04-01 23:01:33.460 Real-time Intraday chart data file updates started for ZTM17_FUT_CBOT | 2020-04-01 23:01:33.460 Intraday chart data file opened for ZTM17_FUT_CBOT | 2020-04-01 23:01:33.460 HD Request # 2 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:01:33.460 Triggering next historical data download in queue. | 2020-04-01 23:01:33.460 HD Request # 3 | Downloading Historical Daily chart data for ZTM17_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:01:33.461 HD Request # 3 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:01:33.461 Socket (3) | Creating socket. | 2020-04-01 23:01:33.461 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:01:33.461 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:01:37.642 Socket (1) | Closed. | 2020-04-01 23:01:37.642 HD Request # 3 | Setting DTC encoding to Binary VLS | 2020-04-01 23:01:41.829 HD Request # 3 | Sending historical data logon request message. | 2020-04-01 23:01:41.829 HD Request # 3 | Requesting historical Daily data starting at 1970-04-02. | 2020-04-01 23:01:48.337 HD Request # 3 | Data is being downloaded from a remote source. Download will start when this is done. | 2020-04-01 23:01:52.510 HD Request # 3 | Decompressing data. | 2020-04-01 23:01:52.510 Socket (3) | CloseSocket call. | 2020-04-01 23:01:52.510 HD Request # 3 | Error downloading historical Daily data for ZTM17_FUT_CBOT. Historical data ZLib Error: incorrect header check | 2020-04-01 23:01:52.510 Historical data download thread signaled to stop. | 2020-04-01 23:01:52.510 HD Request # 3 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZTM17_FUT_CBOT | 2020-04-01 23:01:52.510 HD Request # 3 | Completion time: 19s | 2020-04-01 23:01:52.510 HD Request # 3 | Daily data download complete for ZTM17_FUT_CBOT. Unique request ID: 3 | 2020-04-01 23:01:52.510 Removing historical data download ID 3. | 2020-04-01 23:01:52.510 Triggering next historical data download in queue. | 2020-04-01 23:01:52.510 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:01:52.510 HD Request # 4 | Downloading Intraday chart data for ZTU17_FUT_CBOT to the file ZTU17_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:01:52.512 Compressing file: C:\SierraChart2074\Data\ZTU17_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:01:52.512 HD Request # 4 | Download start date-time: 2017-05-11 20:00:00.000 | 2020-04-01 23:01:52.512 HD Request # 4 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:01:52.512 Socket (1) | Creating socket. | 2020-04-01 23:01:52.512 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:01:52.512 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:01:53.235 Socket (3) | Closed. | 2020-04-01 23:01:53.235 HD Request # 4 | Setting DTC encoding to Binary VLS | 2020-04-01 23:02:01.477 HD Request # 4 | Sending historical data logon request message. | 2020-04-01 23:02:01.477 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:02:05.639 Socket (1) | CloseSocket call. | 2020-04-01 23:02:05.640 Socket (0) | CloseSocket call. | 2020-04-01 23:02:05.640 HD Request # 4 | Error downloading historical Intraday data for ZTU17_FUT_CBOT. The network socket has been closed. Retrying download. | 2020-04-01 23:02:05.640 Socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-04-01 23:02:05.640 Added historical Intraday data request for ZTU17_FUT_CBOT to the queue. | 2020-04-01 23:02:05.640 Triggering next historical data download in queue. | 2020-04-01 23:02:05.640 Socket (1) | Closed. | 2020-04-01 23:02:05.640 Historical data download thread signaled to stop. | 2020-04-01 23:02:05.640 HD Request # 4 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZTU17_FUT_CBOT | 2020-04-01 23:02:05.640 HD Request # 4 | Completion time: 13s | 2020-04-01 23:02:05.640 HD Request # 5 | Downloading Intraday chart data for ZTU17_FUT_CBOT to the file ZTU17_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:02:05.640 HD Request # 5 | Download start date-time: 2017-05-11 20:00:00.000 | 2020-04-01 23:02:05.641 HD Request # 5 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:02:05.642 Socket (1) | Creating socket. | 2020-04-01 23:02:05.642 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:02:05.642 HD Request # 5 | Setting DTC encoding to Binary VLS | 2020-04-01 23:02:11.739 HD Request # 5 | Sending historical data logon request message. | 2020-04-01 23:02:11.739 HD Request # 5 | Requesting Intraday data. Start date-time: 2017-05-11 20:00:00. Record interval: 0. Symbol: ZTU17_FUT_CBOT | 2020-04-01 23:02:20.541 HD Request # 5 | Data is being downloaded from a remote source. Download will start when this is done. | 2020-04-01 23:02:21.587 HD Request # 5 | Decompressing data. | 2020-04-01 23:02:33.849 HD Request # 5 | Receiving Intraday data for ZTU17_FUT_CBOT starting at 2017-05-12 03:59:01 | 2020-04-01 23:02:33.866 HD Request # 5 | Timestamp of first Intraday data file record written: 2017-05-12 03:59:01 | 2020-04-01 23:02:36.546 Socket (1) | CloseSocket call. | 2020-04-01 23:04:28.242 Historical data download thread signaled to stop. | 2020-04-01 23:04:28.242 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:04:28.242 HD Request # 5 | Received 2892193 records from 2017-05-12 03:59:01.000 to 2017-09-29 11:12:39.001 (140.3 days) and wrote 2892193 records for ZTU17_FUT_CBOT | 2020-04-01 23:04:28.242 HD Request # 5 | Completion time: 2m 23s | 2020-04-01 23:04:28.243 HD Request # 5 | Intraday data download complete for ZTU17_FUT_CBOT. Unique request ID: 4 | 2020-04-01 23:04:28.243 Removing historical data download ID 4. | 2020-04-01 23:04:28.243 Real-time Intraday chart data file updates started for ZTU17_FUT_CBOT | 2020-04-01 23:04:28.243 Intraday chart data file opened for ZTU17_FUT_CBOT | 2020-04-01 23:04:28.243 HD Request # 5 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:04:28.243 Triggering next historical data download in queue. | 2020-04-01 23:04:28.243 HD Request # 6 | Downloading Historical Daily chart data for ZTU17_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:04:28.243 HD Request # 6 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:04:28.243 Socket (3) | Creating socket. | 2020-04-01 23:04:28.243 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:04:28.243 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:04:37.692 Socket (1) | Closed. | 2020-04-01 23:04:37.693 HD Request # 6 | Sending historical data logon request message. | 2020-04-01 23:04:38.244 HD Request # 6 | Setting DTC encoding to Binary VLS | 2020-04-01 23:04:42.545 HD Request # 6 | Sending historical data logon request message. | 2020-04-01 23:04:42.545 Socket (3) | CloseSocket call. | 2020-04-01 23:04:42.545 Socket (3) | Write in progress. Shutdown being delayed. | 2020-04-01 23:04:42.545 Socket (3) | Write has completed. Shutdown being performed. | 2020-04-01 23:04:42.545 HD Request # 6 | Error downloading historical Daily data for ZTU17_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:04:42.545 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:04:42.545 Historical data download thread signaled to stop. | 2020-04-01 23:04:42.545 HD Request # 6 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZTU17_FUT_CBOT | 2020-04-01 23:04:42.545 HD Request # 6 | Completion time: 14s | 2020-04-01 23:04:42.545 HD Request # 6 | Daily data download complete for ZTU17_FUT_CBOT. Unique request ID: 5 | 2020-04-01 23:04:42.545 Removing historical data download ID 5. | 2020-04-01 23:04:42.545 Triggering next historical data download in queue. | 2020-04-01 23:04:42.545 HD Request # 7 | Downloading Intraday chart data for ZTZ17_FUT_CBOT to the file ZTZ17_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:04:42.552 Compressing file: C:\SierraChart2074\Data\ZTZ17_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:04:42.553 HD Request # 7 | Download start date-time: 2017-08-13 20:00:00.000 | 2020-04-01 23:04:42.553 HD Request # 7 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:04:42.553 Socket (1) | Creating socket. | 2020-04-01 23:04:42.553 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:04:42.553 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:04:48.626 Socket (3) | Closed. | 2020-04-01 23:04:48.626 HD Request # 7 | Sending historical data logon request message. | 2020-04-01 23:04:52.569 HD Request # 7 | Setting DTC encoding to Binary VLS | 2020-04-01 23:05:02.870 HD Request # 7 | Sending historical data logon request message. | 2020-04-01 23:05:02.870 Socket (1) | CloseSocket call. | 2020-04-01 23:05:02.870 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:05:02.870 HD Request # 7 | Error downloading historical Intraday data for ZTZ17_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:05:02.870 Historical data download thread signaled to stop. | 2020-04-01 23:05:02.871 HD Request # 7 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZTZ17_FUT_CBOT | 2020-04-01 23:05:02.871 HD Request # 7 | Completion time: 20s | 2020-04-01 23:05:02.872 HD Request # 7 | Intraday data download complete for ZTZ17_FUT_CBOT. Unique request ID: 6 | 2020-04-01 23:05:02.872 Removing historical data download ID 6. | 2020-04-01 23:05:02.872 Real-time Intraday chart data file updates started for ZTZ17_FUT_CBOT | 2020-04-01 23:05:02.872 Intraday chart data file opened for ZTZ17_FUT_CBOT | 2020-04-01 23:05:02.872 HD Request # 7 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:05:02.872 Triggering next historical data download in queue. | 2020-04-01 23:05:02.872 HD Request # 8 | Downloading Historical Daily chart data for ZTZ17_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:05:02.873 HD Request # 8 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:05:02.873 Socket (3) | Creating socket. | 2020-04-01 23:05:02.873 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:05:02.874 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:05:06.743 Socket (1) | Closed. | 2020-04-01 23:05:06.743 HD Request # 8 | Sending historical data logon request message. | 2020-04-01 23:05:12.877 HD Request # 8 | Setting DTC encoding to Binary VLS | 2020-04-01 23:05:17.049 HD Request # 8 | Sending historical data logon request message. | 2020-04-01 23:05:17.049 Socket (3) | CloseSocket call. | 2020-04-01 23:05:17.049 HD Request # 8 | Error downloading historical Daily data for ZTZ17_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:05:17.049 Socket (3) | Write in progress. Shutdown being delayed. | 2020-04-01 23:05:17.049 Socket (3) | Write has completed. Shutdown being performed. | 2020-04-01 23:05:17.050 Historical data download thread signaled to stop. | 2020-04-01 23:05:17.050 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:05:17.050 HD Request # 8 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZTZ17_FUT_CBOT | 2020-04-01 23:05:17.050 HD Request # 8 | Completion time: 15s | 2020-04-01 23:05:17.050 HD Request # 8 | Daily data download complete for ZTZ17_FUT_CBOT. Unique request ID: 7 | 2020-04-01 23:05:17.050 Removing historical data download ID 7. | 2020-04-01 23:05:17.050 Triggering next historical data download in queue. | 2020-04-01 23:05:17.050 HD Request # 9 | Downloading Intraday chart data for ZTH18_FUT_CBOT to the file ZTH18_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:05:17.056 Compressing file: C:\SierraChart2074\Data\ZTH18_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:05:17.056 HD Request # 9 | Download start date-time: 2017-11-12 19:00:00.000 | 2020-04-01 23:05:17.056 HD Request # 9 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:05:17.056 Socket (1) | Creating socket. | 2020-04-01 23:05:17.056 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:05:17.056 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:05:21.302 Socket (3) | Closed. | 2020-04-01 23:05:21.302 HD Request # 9 | Sending historical data logon request message. | 2020-04-01 23:05:27.051 HD Request # 9 | Setting DTC encoding to Binary VLS | 2020-04-01 23:05:28.602 HD Request # 9 | Sending historical data logon request message. | 2020-04-01 23:05:28.602 Socket (1) | CloseSocket call. | 2020-04-01 23:05:35.115 HD Request # 9 | Error downloading historical Intraday data for ZTH18_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:05:35.116 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:05:35.116 Historical data download thread signaled to stop. | 2020-04-01 23:05:35.116 HD Request # 9 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZTH18_FUT_CBOT | 2020-04-01 23:05:35.116 HD Request # 9 | Completion time: 18s | 2020-04-01 23:05:35.117 HD Request # 9 | Intraday data download complete for ZTH18_FUT_CBOT. Unique request ID: 8 | 2020-04-01 23:05:35.117 Removing historical data download ID 8. | 2020-04-01 23:05:35.117 Real-time Intraday chart data file updates started for ZTH18_FUT_CBOT | 2020-04-01 23:05:35.117 Intraday chart data file opened for ZTH18_FUT_CBOT | 2020-04-01 23:05:35.117 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:05:35.117 Triggering next historical data download in queue. | 2020-04-01 23:05:35.117 HD Request # 10 | Downloading Historical Daily chart data for ZTH18_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:05:35.118 HD Request # 10 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:05:35.118 Socket (3) | Creating socket. | 2020-04-01 23:05:35.118 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:05:35.119 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:05:38.144 Socket (1) | Closed. | 2020-04-01 23:05:38.144 HD Request # 10 | Sending historical data logon request message. | 2020-04-01 23:05:45.107 HD Request # 10 | Setting DTC encoding to Binary VLS | 2020-04-01 23:05:45.953 HD Request # 10 | Sending historical data logon request message. | 2020-04-01 23:05:45.953 Socket (3) | CloseSocket call. | 2020-04-01 23:05:48.200 HD Request # 10 | Error downloading historical Daily data for ZTH18_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:05:48.200 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:05:48.200 Historical data download thread signaled to stop. | 2020-04-01 23:05:48.200 HD Request # 10 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZTH18_FUT_CBOT | 2020-04-01 23:05:48.200 HD Request # 10 | Completion time: 13s | 2020-04-01 23:05:48.200 HD Request # 10 | Daily data download complete for ZTH18_FUT_CBOT. Unique request ID: 9 | 2020-04-01 23:05:48.200 Removing historical data download ID 9. | 2020-04-01 23:05:48.200 Triggering next historical data download in queue. | 2020-04-01 23:05:48.200 HD Request # 11 | Downloading Intraday chart data for ZTM18_FUT_CBOT to the file ZTM18_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:05:48.204 Compressing file: C:\SierraChart2074\Data\ZTM18_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:05:48.204 HD Request # 11 | Download start date-time: 2018-02-08 19:00:00.000 | 2020-04-01 23:05:48.204 HD Request # 11 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:05:48.204 Socket (1) | Creating socket. | 2020-04-01 23:05:48.205 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:05:48.205 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:05:48.270 Socket (3) | Closed. | 2020-04-01 23:05:48.270 HD Request # 11 | Setting DTC encoding to Binary VLS | 2020-04-01 23:05:50.136 HD Request # 11 | Sending historical data logon request message. | 2020-04-01 23:05:50.136 HD Request # 11 | Requesting Intraday data. Start date-time: 2018-02-08 19:00:00. Record interval: 0. Symbol: ZTM18_FUT_CBOT | 2020-04-01 23:05:52.555 HD Request # 11 | Decompressing data. | 2020-04-01 23:05:57.049 HD Request # 11 | Receiving Intraday data for ZTM18_FUT_CBOT starting at 2018-02-08 19:14:36 | 2020-04-01 23:05:57.104 HD Request # 11 | Timestamp of first Intraday data file record written: 2018-02-08 19:14:36 | 2020-04-01 23:05:58.718 Socket (1) | CloseSocket call. | 2020-04-01 23:08:30.815 Historical data download thread signaled to stop. | 2020-04-01 23:08:30.816 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:08:30.816 HD Request # 11 | Received 3374649 records from 2018-02-08 19:14:36.000 to 2018-06-29 13:00:13.000 (140.7 days) and wrote 3374649 records for ZTM18_FUT_CBOT | 2020-04-01 23:08:30.816 HD Request # 11 | Completion time: 2m 42s | 2020-04-01 23:08:30.816 HD Request # 11 | Intraday data download complete for ZTM18_FUT_CBOT. Unique request ID: 10 | 2020-04-01 23:08:30.816 Removing historical data download ID 10. | 2020-04-01 23:08:30.816 Real-time Intraday chart data file updates started for ZTM18_FUT_CBOT | 2020-04-01 23:08:30.816 Intraday chart data file opened for ZTM18_FUT_CBOT | 2020-04-01 23:08:30.816 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:08:30.816 Triggering next historical data download in queue. | 2020-04-01 23:08:30.816 HD Request # 12 | Downloading Historical Daily chart data for ZTM18_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:08:30.817 HD Request # 12 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:08:30.817 Socket (3) | Creating socket. | 2020-04-01 23:08:30.817 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:08:30.817 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:08:34.762 Socket (1) | Closed. | 2020-04-01 23:08:34.762 HD Request # 12 | Setting DTC encoding to Binary VLS | 2020-04-01 23:08:35.851 HD Request # 12 | Sending historical data logon request message. | 2020-04-01 23:08:35.851 HD Request # 12 | Requesting historical Daily data starting at 1970-04-02. | 2020-04-01 23:08:47.296 HD Request # 12 | Data is being downloaded from a remote source. Download will start when this is done. | 2020-04-01 23:08:53.919 HD Request # 12 | Decompressing data. | 2020-04-01 23:08:53.922 HD Request # 12 | Receiving historical Daily data for ZTM18_FUT_CBOT starting at 2017-09-29 | 2020-04-01 23:08:53.922 HD Request # 12 | Writing historical Daily data to the file ZTM18_FUT_CBOT.dly | 2020-04-01 23:08:53.922 Socket (3) | CloseSocket call. | 2020-04-01 23:08:53.923 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:08:53.923 Historical data download thread signaled to stop. | 2020-04-01 23:08:53.923 HD Request # 12 | Received 189 records from 2017-09-29 00:00:00 to 2018-06-29 00:00:00 (274.0 days) and wrote 189 records for ZTM18_FUT_CBOT | 2020-04-01 23:08:53.923 HD Request # 12 | Completion time: 23s | 2020-04-01 23:08:53.923 HD Request # 12 | Daily data download complete for ZTM18_FUT_CBOT. Unique request ID: 11 | 2020-04-01 23:08:53.923 Removing historical data download ID 11. | 2020-04-01 23:08:53.923 Triggering next historical data download in queue. | 2020-04-01 23:08:53.923 HD Request # 13 | Downloading Intraday chart data for ZTU18_FUT_CBOT to the file ZTU18_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:08:53.925 Compressing file: C:\SierraChart2074\Data\ZTU18_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:08:53.925 HD Request # 13 | Download start date-time: 2018-05-13 20:00:00.000 | 2020-04-01 23:08:53.925 HD Request # 13 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:08:53.925 Socket (1) | Creating socket. | 2020-04-01 23:08:53.925 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:08:53.925 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:08:57.611 Socket (3) | Closed. | 2020-04-01 23:08:57.611 HD Request # 13 | Sending historical data logon request message. | 2020-04-01 23:09:03.914 HD Request # 13 | Setting DTC encoding to Binary VLS | 2020-04-01 23:09:04.576 HD Request # 13 | Sending historical data logon request message. | 2020-04-01 23:09:04.576 Socket (1) | CloseSocket call. | 2020-04-01 23:09:04.670 HD Request # 13 | Error downloading historical Intraday data for ZTU18_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:09:04.670 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:09:04.670 Historical data download thread signaled to stop. | 2020-04-01 23:09:04.670 HD Request # 13 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZTU18_FUT_CBOT | 2020-04-01 23:09:04.670 HD Request # 13 | Completion time: 11s | 2020-04-01 23:09:04.670 HD Request # 13 | Intraday data download complete for ZTU18_FUT_CBOT. Unique request ID: 12 | 2020-04-01 23:09:04.670 Removing historical data download ID 12. | 2020-04-01 23:09:04.670 Real-time Intraday chart data file updates started for ZTU18_FUT_CBOT | 2020-04-01 23:09:04.670 Intraday chart data file opened for ZTU18_FUT_CBOT | 2020-04-01 23:09:04.670 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:09:04.670 Triggering next historical data download in queue. | 2020-04-01 23:09:04.670 HD Request # 14 | Downloading Historical Daily chart data for ZTU18_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:09:04.671 HD Request # 14 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:09:04.671 Socket (3) | Creating socket. | 2020-04-01 23:09:04.671 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:09:04.671 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:09:05.867 Socket (1) | Closed. | 2020-04-01 23:09:05.867 HD Request # 14 | Setting DTC encoding to Binary VLS | 2020-04-01 23:09:11.910 HD Request # 14 | Sending historical data logon request message. | 2020-04-01 23:09:11.910 HD Request # 14 | Requesting historical Daily data starting at 1970-04-02. | 2020-04-01 23:09:17.670 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:09:25.284 Socket (3) | CloseSocket call. | 2020-04-01 23:09:25.284 Socket (0) | CloseSocket call. | 2020-04-01 23:09:25.284 Socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-04-01 23:09:25.284 Socket (3) | Closed. | 2020-04-01 23:09:25.284 HD Request # 14 | Error downloading historical Daily data for ZTU18_FUT_CBOT. The network socket has been closed. Retrying download. | 2020-04-01 23:09:25.284 Added historical Daily data request for ZTU18_FUT_CBOT to the queue. | 2020-04-01 23:09:25.284 Triggering next historical data download in queue. | 2020-04-01 23:09:25.284 Historical data download thread signaled to stop. | 2020-04-01 23:09:25.284 HD Request # 14 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZTU18_FUT_CBOT | 2020-04-01 23:09:25.284 HD Request # 14 | Completion time: 21s | 2020-04-01 23:09:25.284 HD Request # 15 | Downloading Historical Daily chart data for ZTU18_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:09:25.285 HD Request # 15 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:09:25.285 Socket (1) | Creating socket. | 2020-04-01 23:09:25.285 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:09:25.285 HD Request # 15 | Setting DTC encoding to Binary VLS | 2020-04-01 23:09:32.194 HD Request # 15 | Sending historical data logon request message. | 2020-04-01 23:09:32.194 HD Request # 15 | Requesting historical Daily data starting at 1970-04-02. | 2020-04-01 23:09:37.867 HD Request # 15 | Data is being downloaded from a remote source. Download will start when this is done. | 2020-04-01 23:09:45.196 HD Request # 15 | Decompressing data. | 2020-04-01 23:09:45.198 HD Request # 15 | Receiving historical Daily data for ZTU18_FUT_CBOT starting at 2017-12-18 | 2020-04-01 23:09:45.198 HD Request # 15 | Writing historical Daily data to the file ZTU18_FUT_CBOT.dly | 2020-04-01 23:09:45.198 Socket (1) | CloseSocket call. | 2020-04-01 23:09:45.200 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:09:45.200 Historical data download thread signaled to stop. | 2020-04-01 23:09:45.200 HD Request # 15 | Received 197 records from 2017-12-18 00:00:00 to 2018-09-28 00:00:00 (285.0 days) and wrote 197 records for ZTU18_FUT_CBOT | 2020-04-01 23:09:45.200 HD Request # 15 | Completion time: 20s | 2020-04-01 23:09:45.200 HD Request # 15 | Daily data download complete for ZTU18_FUT_CBOT. Unique request ID: 13 | 2020-04-01 23:09:45.200 Removing historical data download ID 13. | 2020-04-01 23:09:45.200 Triggering next historical data download in queue. | 2020-04-01 23:09:45.200 HD Request # 16 | Downloading Intraday chart data for ZTZ18_FUT_CBOT to the file ZTZ18_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:09:45.201 Compressing file: C:\SierraChart2074\Data\ZTZ18_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:09:45.201 HD Request # 16 | Download start date-time: 2018-08-13 20:00:00.000 | 2020-04-01 23:09:45.201 HD Request # 16 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:09:45.201 Socket (3) | Creating socket. | 2020-04-01 23:09:45.201 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:09:45.202 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:09:49.026 Socket (1) | Closed. | 2020-04-01 23:09:49.026 HD Request # 16 | Sending historical data logon request message. | 2020-04-01 23:09:55.181 HD Request # 16 | Setting DTC encoding to Binary VLS | 2020-04-01 23:09:58.199 HD Request # 16 | Sending historical data logon request message. | 2020-04-01 23:09:58.199 Socket (3) | CloseSocket call. | 2020-04-01 23:09:58.200 HD Request # 16 | Error downloading historical Intraday data for ZTZ18_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:09:58.200 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:09:58.200 Historical data download thread signaled to stop. | 2020-04-01 23:09:58.200 HD Request # 16 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZTZ18_FUT_CBOT | 2020-04-01 23:09:58.200 HD Request # 16 | Completion time: 13s | 2020-04-01 23:09:58.200 HD Request # 16 | Intraday data download complete for ZTZ18_FUT_CBOT. Unique request ID: 14 | 2020-04-01 23:09:58.200 Removing historical data download ID 14. | 2020-04-01 23:09:58.200 Real-time Intraday chart data file updates started for ZTZ18_FUT_CBOT | 2020-04-01 23:09:58.200 Intraday chart data file opened for ZTZ18_FUT_CBOT | 2020-04-01 23:09:58.200 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:09:58.200 Triggering next historical data download in queue. | 2020-04-01 23:09:58.200 HD Request # 17 | Downloading Historical Daily chart data for ZTZ18_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:09:58.201 HD Request # 17 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:09:58.201 Socket (1) | Creating socket. | 2020-04-01 23:09:58.201 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:09:58.201 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:10:02.557 Socket (3) | Closed. | 2020-04-01 23:10:02.557 HD Request # 17 | Setting DTC encoding to Binary VLS | 2020-04-01 23:10:06.652 HD Request # 17 | Sending historical data logon request message. | 2020-04-01 23:10:06.652 HD Request # 17 | Requesting historical Daily data starting at 1970-04-02. | 2020-04-01 23:10:07.298 HD Request # 17 | Data is being downloaded from a remote source. Download will start when this is done. | 2020-04-01 23:10:09.892 HD Request # 17 | Decompressing data. | 2020-04-01 23:10:09.895 HD Request # 17 | Receiving historical Daily data for ZTZ18_FUT_CBOT starting at 2018-03-29 | 2020-04-01 23:10:09.895 HD Request # 17 | Writing historical Daily data to the file ZTZ18_FUT_CBOT.dly | 2020-04-01 23:10:09.895 Socket (1) | CloseSocket call. | 2020-04-01 23:10:09.897 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:10:09.897 Historical data download thread signaled to stop. | 2020-04-01 23:10:09.897 HD Request # 17 | Received 192 records from 2018-03-29 00:00:00 to 2018-12-31 00:00:00 (278.0 days) and wrote 192 records for ZTZ18_FUT_CBOT | 2020-04-01 23:10:09.897 HD Request # 17 | Completion time: 11s | 2020-04-01 23:10:09.897 HD Request # 17 | Daily data download complete for ZTZ18_FUT_CBOT. Unique request ID: 15 | 2020-04-01 23:10:09.897 Removing historical data download ID 15. | 2020-04-01 23:10:09.897 Triggering next historical data download in queue. | 2020-04-01 23:10:09.897 HD Request # 18 | Downloading Intraday chart data for ZTH19_FUT_CBOT to the file ZTH19_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:10:09.898 Compressing file: C:\SierraChart2074\Data\ZTH19_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:10:09.898 HD Request # 18 | Download start date-time: 2018-11-12 19:00:00.000 | 2020-04-01 23:10:09.898 HD Request # 18 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:10:09.898 Socket (3) | Creating socket. | 2020-04-01 23:10:09.898 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:10:09.898 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:10:15.618 Socket (1) | Closed. | 2020-04-01 23:10:15.618 HD Request # 18 | Sending historical data logon request message. | 2020-04-01 23:10:19.900 HD Request # 18 | Setting DTC encoding to Binary VLS | 2020-04-01 23:10:22.207 HD Request # 18 | Sending historical data logon request message. | 2020-04-01 23:10:22.207 Socket (3) | CloseSocket call. | 2020-04-01 23:10:22.207 HD Request # 18 | Error downloading historical Intraday data for ZTH19_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:10:22.207 Socket (3) | Write in progress. Shutdown being delayed. | 2020-04-01 23:10:22.207 Socket (3) | Write has completed. Shutdown being performed. | 2020-04-01 23:10:22.207 Historical data download thread signaled to stop. | 2020-04-01 23:10:22.207 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:10:22.207 HD Request # 18 | Received 0 records from 00:00:00.000 to 00:00:00.000 (0.0 seconds) and wrote 0 records for ZTH19_FUT_CBOT | 2020-04-01 23:10:22.207 HD Request # 18 | Completion time: 13s | 2020-04-01 23:10:22.208 HD Request # 18 | Intraday data download complete for ZTH19_FUT_CBOT. Unique request ID: 16 | 2020-04-01 23:10:22.208 Removing historical data download ID 16. | 2020-04-01 23:10:22.208 Real-time Intraday chart data file updates started for ZTH19_FUT_CBOT | 2020-04-01 23:10:22.208 Intraday chart data file opened for ZTH19_FUT_CBOT | 2020-04-01 23:10:22.208 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:10:22.208 Triggering next historical data download in queue. | 2020-04-01 23:10:22.208 HD Request # 19 | Downloading Historical Daily chart data for ZTH19_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:10:22.208 HD Request # 19 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:10:22.208 Socket (1) | Creating socket. | 2020-04-01 23:10:22.208 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:10:22.208 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:10:29.929 Socket (3) | Closed. | 2020-04-01 23:10:29.929 HD Request # 19 | Sending historical data logon request message. | 2020-04-01 23:10:32.196 HD Request # 19 | Setting DTC encoding to Binary VLS | 2020-04-01 23:10:36.673 HD Request # 19 | Sending historical data logon request message. | 2020-04-01 23:10:36.673 Socket (1) | CloseSocket call. | 2020-04-01 23:10:36.674 Socket (1) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:10:36.674 HD Request # 19 | Error downloading historical Daily data for ZTH19_FUT_CBOT. Historical data logon error: Unsupported protocol version | 2020-04-01 23:10:36.674 Historical data download thread signaled to stop. | 2020-04-01 23:10:36.674 HD Request # 19 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZTH19_FUT_CBOT | 2020-04-01 23:10:36.674 HD Request # 19 | Completion time: 14s | 2020-04-01 23:10:36.674 HD Request # 19 | Daily data download complete for ZTH19_FUT_CBOT. Unique request ID: 17 | 2020-04-01 23:10:36.674 Removing historical data download ID 17. | 2020-04-01 23:10:36.674 Triggering next historical data download in queue. | 2020-04-01 23:10:36.674 HD Request # 20 | Downloading Intraday chart data for ZTM19_FUT_CBOT to the file ZTM19_FUT_CBOT.scid. Service: DTCSubInstance | 2020-04-01 23:10:36.676 Compressing file: C:\SierraChart2074\Data\ZTM19_FUT_CBOT.scid. This may take a while. | 2020-04-01 23:10:36.676 HD Request # 20 | Download start date-time: 2019-02-10 19:00:00.000 | 2020-04-01 23:10:36.676 HD Request # 20 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:10:36.676 Socket (3) | Creating socket. | 2020-04-01 23:10:36.676 Socket (3) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:10:36.676 Socket (1) | Socket gracefully closed by remote side. | 2020-04-01 23:10:38.967 Socket (1) | Closed. | 2020-04-01 23:10:38.967 HD Request # 20 | Setting DTC encoding to Binary VLS | 2020-04-01 23:10:44.247 HD Request # 20 | Sending historical data logon request message. | 2020-04-01 23:10:44.247 HD Request # 20 | Requesting Intraday data. Start date-time: 2019-02-10 19:00:00. Record interval: 0. Symbol: ZTM19_FUT_CBOT | 2020-04-01 23:10:51.150 HD Request # 20 | Decompressing data. | 2020-04-01 23:10:57.638 HD Request # 20 | Receiving Intraday data for ZTM19_FUT_CBOT starting at 2019-02-10 23:30:12 | 2020-04-01 23:10:57.639 HD Request # 20 | Timestamp of first Intraday data file record written: 2019-02-10 23:30:12 | 2020-04-01 23:11:00.572 Socket (3) | CloseSocket call. | 2020-04-01 23:16:18.086 Historical data download thread signaled to stop. | 2020-04-01 23:16:18.086 Socket (3) | Shutdown started. Waiting for graceful close. | 2020-04-01 23:16:18.086 HD Request # 20 | Received 4375031 records from 2019-02-10 23:30:12.000 to 2019-06-28 11:48:35.000 (137.5 days) and wrote 4375031 records for ZTM19_FUT_CBOT | 2020-04-01 23:16:18.088 HD Request # 20 | Completion time: 5m 42s | 2020-04-01 23:16:18.089 HD Request # 20 | Intraday data download complete for ZTM19_FUT_CBOT. Unique request ID: 18 | 2020-04-01 23:16:18.089 Removing historical data download ID 18. | 2020-04-01 23:16:18.089 Real-time Intraday chart data file updates started for ZTM19_FUT_CBOT | 2020-04-01 23:16:18.089 Intraday chart data file opened for ZTM19_FUT_CBOT | 2020-04-01 23:16:18.089 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2020-04-01 23:16:18.089 Triggering next historical data download in queue. | 2020-04-01 23:16:18.089 HD Request # 21 | Downloading Historical Daily chart data for ZTM19_FUT_CBOT. Starting date: 1970-04-02. Service: DTCSubInstance | 2020-04-01 23:16:18.090 HD Request # 21 | Using server: 127.0.0.1 port 22222 | 2020-04-01 23:16:18.090 Socket (1) | Creating socket. | 2020-04-01 23:16:18.091 Socket (1) | Connecting to IP: 127.0.0.1. | 2020-04-01 23:16:18.091 Socket (3) | Socket gracefully closed by remote side. | 2020-04-01 23:16:18.809 Socket (3) | Closed. | 2020-04-01 23:16:18.810 |
[2020-04-02 03:38:44] |
I guess worry is in order, since four of the contracts don't download, even after the chart loads. ZTH18, ZTU18, ZTZ17, and ZTZ18 are missing to be specific. C:\SierraChart2074\Data$ ls -al ZT*scid
-rwxrwx---+ 1 me None 56 Apr 1 22:58 ZTH18_FUT_CBOT.scid -rwxrwx---+ 1 me None 56 Apr 1 22:58 ZTH19_FUT_CBOT.scid -rwxrwx---+ 1 me None 205444456 Apr 1 22:56 ZTH20_FUT_CBOT.scid -rwxrwx---+ 1 me None 119343896 Apr 1 23:01 ZTM17_FUT_CBOT.scid -rwxrwx---+ 1 me None 134986016 Apr 1 23:08 ZTM18_FUT_CBOT.scid -rwxrwx---+ 1 me None 175001296 Apr 1 23:16 ZTM19_FUT_CBOT.scid -rwxrwx---+ 1 me None 212317296 Apr 1 23:33 ZTM20_FUT_CBOT.scid -rwxrwx---+ 1 me None 115687776 Apr 1 23:04 ZTU17_FUT_CBOT.scid -rwxrwx---+ 1 me None 56 Apr 1 22:58 ZTU18_FUT_CBOT.scid -rwxrwx---+ 1 me None 211452336 Apr 1 23:23 ZTU19_FUT_CBOT.scid -rwxrwx---+ 1 me None 56 Apr 1 22:58 ZTZ17_FUT_CBOT.scid -rwxrwx---+ 1 me None 56 Apr 1 22:58 ZTZ18_FUT_CBOT.scid -rwxrwx---+ 1 me None 222075096 Apr 1 23:28 ZTZ19_FUT_CBOT.scid Date Time Of Last Edit: 2020-04-02 03:38:56
[2020-04-02 05:39:25] |
Our best analysis of this is there is some corruption occurring with network communication on your computer. We recommend a restart of your computer. There really is no other explanation. The datastream is just getting corrupted. Also if you are running any custom studies, then run Sierra Chart in Safe Mode. So the issue is specific to your system and any custom studies you are running which could be causing a problem. So this could be another cause. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-02 05:39:43
[2020-04-02 17:36:44] |
So in one case you had this problem when connecting version 2052 to version 2057? We saw something similar to this, but it was just a one-off incident and it was not reproducible. It could also be an issue at the Windows operating system level as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-02 17:37:37
