Date/Time: Wed, 05 Feb 2025 21:55:40 +0000
Attached Orders not modified
View Count: 519
[2020-04-01 19:44:15] |
User53601 - Posts: 106 |
Hello, In Live trading using Interactive Brokers, an issue occured I did not see so far. In an open position, when the price of a parent order is modified, the Attached Orders for it are not modified to maintain the same offset they had to the parent order previously. In Sim mode it works ok. Can you please give an advice. |
[2020-04-02 07:21:14] |
Yes we have heard this with Interactive Brokers. They must have changed the ability to modify the child orders when they are fully server-side managed, until only after the parent order has filled. Our only suggestion is to disable this option: Global Trade Settings Windows: Use Server Side Bracket Orders (if supported) (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
