Date/Time: Mon, 14 Sep 2026 16:04:01 +0000
[Programming Help] - sc.RecalculateChartImmediate
View Count: 925
[2020-04-01 17:53:25]
User869657 - Posts: 31
Hello
I'm trying to use sc.SetChartStudyInputInt combined with sc.RecalculateChartImmediate() ; this works great but as stated in the doc of sc.RecalculateChartImmediate(), "the clearing of arrays does not happen", which means that when I export data outside SC for further analysis, I end up retrieving the results of the previous inputs values' runs as well
I couldn't find a function that clears the arrays, could you please let me know if there is one ? What I'm trying to achieve is to loop an input through different values, and for each retrieve data of the run to analyse.
Many thanks in advance
ACSIL Interface Members - Functions: sc.RecalculateChartImmediate()
[2020-04-01 19:17:49]
The study itself will have to clear the arrays. Just simply set the values of the used Subgraph arrays to 0 at the elements where you want them to be zero.
[2020-04-17 08:36:54]
Thanks again for your reply, I managed to get it working using your advice.
However, I am facing another issue : setting an input's value through a for loop using sc.SetChartStudyInputInt and sc.RecalculateChartImmediate works great. But importing a SG's value from that same chart after recalculating it seems to trigger again the for loop, which then never ends. This has been tested using both automatic and manual looping
Attached a short code with this issue : adding line 27 (sc.GetStudyArrayFromChartUsingID) seems to trigger the endless repeat of for loop
Could you please let me know if I misunderstood something about these functions
Many thanks in advance.
attachmenttest.cpp - Attached On 2020-04-17 08:34:18 UTC - Size: 650 B - 387 views
