Date/Time: Wed, 05 Feb 2025 22:50:44 +0000
CBOT Realtime Data
View Count: 1230
[2020-04-01 16:50:23] |
Antonino De Rosa - Posts: 47 |
Dear SC support Team, i need the CBOT Exchange realtime data. I don`t find it under the available exchanges for activate. What can i do for activate. Best regards Antonino |
[2020-04-02 19:16:43] |
The CME group of data is now only offered through the Denali Exchange Data Feed: Denali Exchange Data Feed You receive a $12 credit to your account when using the Sierra Chart Exchange Data Feed and the Denali feed at the same time. Which makes the cost of the feed only 8 USD extra per month. We will set up the Denali data for for you. Did you require market depth data for the CBOT? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-02 19:41:23] |
Could you quote me the exact price when I want to use CBOT and EUREX together ? No CME at the moment. Many thanks Kind regards Antonino |
[2020-04-03 00:35:08] |
SC Support - Posts: 1927 |
Hi Antonino, Regarding the CBOT do you need Market Depth? Denali Exchange Data Feed: Supported Exchanges (Exchange Fees) |
[2020-04-03 06:37:31] |
Hi, yes I do, Level2 for all the Exchanges what I trade. Thank you. Regards Antonino |
[2020-04-03 18:50:32] |
Dear SC Team, can you do something in my case please. Eurex and CBOT and eventually later CME full depth Level 2 ?? Would be much appreciated. Many thanks Regards Antonino |
[2020-04-03 19:21:20] |
Hi Antonino, you should have that live data flowing to your charts now - From the Denali Data Feed you are getting: CBOT Level 2 CME Level 2 (Courtesy Trial from the CME) From the Sierra Chart Exchange Data Feed, you are getting: EUREX Level 2 Can you confirm that you are seeing that live data flowing to your charts? |
[2020-04-03 19:48:49] |
Dear SC Team, many thanks. As i`ve checked I see flowing live Datas in some Eurex, CBOT and CME charts. How do I pay now for this bundle. Many many thanks for teh avaibility. Kind regards Antonino |
[2020-04-06 14:43:14] |
The monthly Data cost for this set-up $25.00 - (1) Denali Data Feed $10.40 - CBOT Level 2 $10.40 - CME Level 2 $25.00 - (2) Sierra Chart Exchange Data Feed $21.00 - EUREX Level 2 -$10.00 - Rebate for Clients on both (1) Denali + (2) Sierra Chart Exchange Data Feed $81.80 - Total |
