Date/Time: Fri, 03 May 2024 18:45:12 +0000
Data feed issue
View Count: 551
[2020-04-01 14:42:38] |
User495734 - Posts: 22 |
hi, My charts are lagging heavily, and the timer keeps freezing. as u can see i have the clock study open, and the timing does not coincide with the timer on the top right hand in the photo. I have checked my PC and it is either a sierra chart issue or with the data feed. Am currently using the denali feed which i have activated. please assist |
data issue.PNG / V - Attached On 2020-04-01 14:41:16 UTC - Size: 5.07 KB - 203 views |
[2020-04-01 16:30:45] |
Is your computer's clock set correctly? The timer is not going to continuously update unless it is set to. Refer to this Input setting: Countdown Timer Also refer to: Prices / Data Falling Behind Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-04-01 16:31:32
[2020-04-06 13:38:13] |
the clock setting is fine, the feed seems to be lagging, sometimes with a 2-3 second delay sometimes with a 5-6 second delay. the price just freezes for those seconds.
[2020-04-06 18:39:56] |
This is not unusual because the market is not always continuously trading.
