Date/Time: Wed, 05 Feb 2025 21:56:01 +0000
Data connection
View Count: 678
[2020-04-01 12:38:54] |
User161549 - Posts: 81 |
I am aware of the new CME data fees and am aware of the new procedure of only allowing one system to run on your data plan that was to go into effect April 1st Pulled up sierra on 2 of my of my computers and my main is still printing normally and my second is still printing data but is extremely slow Curious to know when and how will this go into effect will my second system just stop printing data period or will it turn into delayed ? Date Time Of Last Edit: 2020-04-01 15:55:16
[2020-04-01 17:21:43] |
my second is still printing data but is extremely slow Refer to help topic 4:Prices / Data Falling Behind Curious to know when and how will this go into effect will my second system just stop printing data period or will it turn into delayed ? It will go into effect in a few days. You are able to use delayed data:Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-04-02 16:27:11] |
When it goes into effect out of the two systems i use will it randomly just pick one to send the data through or is there something i need to do to specify which computer i need the data too ? Also when it goes into effect will the second system that doesnt receive the data feed automatically switch to delayed data or is that something i need to manually change as well ? |
[2020-04-02 18:00:05] |
It will strictly depend upon which installation of Sierra Chart is connecting first. To use delayed data, follow the instructions in this post: Notice: CME Fees Price Increase / Denali Exchange Data Feed Connection Management | Post: 212961 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
