Date/Time: Wed, 05 Feb 2025 20:12:59 +0000
Non delayed data feed
View Count: 611
[2020-04-01 08:47:08]
DF86 - Posts: 14
Hi, Im trying to find out how i get this. Currently im on the 14 day trial and intending to carry on my subscription once this ends. If my underdstanding is correct i can only access a delayed data feed for spx at the moment. I have no funded trading account that you list, what is the easiest way for me to get non delayed realtime chart and DOM data?
Cheers
[2020-04-01 08:53:41]
Tell us the exact symbol you are referring to. There is no symbol exactly as SPX.
Date Time Of Last Edit: 2020-04-01 08:53:53
[2020-04-01 09:20:47]
DF86 - Posts: 14
Thanks for quick response. The s@p 500 indice is what im after, I think its the esm20 symbol. Although any i can use in real time is fine
[2020-04-01 09:28:21]
If you require real-time futures data, then refer to:
https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php
Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data.
