Date/Time: Wed, 05 Feb 2025 20:14:31 +0000
edit global symbol settings not opening from chart settings
View Count: 499
[2020-04-01 06:26:15] |
arruga - Posts: 253 |
i can access the global symbol settings from Global settings --> symbol settings But from chart settings --> Edit global settings, it doesn't do anything I'm on SC 2057 please advise |
[2020-04-01 09:37:20] |
We cannot reproduce this issue. Probably due to this: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.40 - Dialog Windows Do Not Display Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
