Date/Time: Wed, 05 Feb 2025 20:00:10 +0000
Glitch since new update - Use Date Range settings and continuous contract
View Count: 504
[2020-04-01 02:07:21]
User353585 - Posts: 66
hello
since the new update, continuous contracts are not loaded with Use Date Range settings.
I normally leave "To:" input empty for convenience and it seems that is part of the problem. If I manually set "to:" input to today, then it works ok.
It's never been a problem until I updated to new version (2072). I rolled back to 2068 and the problem disappeared.
could you check on this? thanks.
Date Time Of Last Edit: 2020-04-01 02:08:15
[2020-04-01 03:09:51]
Yes we will look into this.
[2020-04-01 09:17:06]
We have this resolved and there will be a new release out in about an hour.
