Date/Time: Mon, 25 Nov 2024 04:46:31 +0000
chart scale
View Count: 1146
[2014-01-12 08:37:21] |
saxo12 - Posts: 38 |
mrkt profile chart will not show the full range ie 4/5 ticks missing from top and bottom of the full range of the days on the chart (one day or several) the scale is set as the bar charts that work fine. Is there a function to 'grab and pull' |
[2014-01-12 08:52:01] |
Select Chart >> Reset Scales. For information about Interactive Scaling, refer to: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-12 08:52:13
