Date/Time: Wed, 05 Feb 2025 20:13:46 +0000
Software Download Error Message
View Count: 516
[2020-03-31 20:00:11]
User300550 - Posts: 1
Hello
I need assistance to download your software. I followed the instructions for you online support and still keep gettin the same error message
"Error download files to local system. Stopped installation. Check Log. Press " install to retry".
Account Name: Strategic Wealth Designs LLC
Thank you
[2020-04-01 09:00:00]
The easiest thing may be just to use the zip installer here:
Software Download: Sierra Chart Zip Installer
This is what we recommend doing. You just extract the files into C:\SierraChart
Also refer to the following information in case it applies:
Software Download: Resolving 'Access is Denied' Errors
Date Time Of Last Edit: 2020-04-01 09:00:14
