Date/Time: Wed, 05 Feb 2025 19:59:30 +0000
I want to switch to denali. Question about depth levels
View Count: 558
[2020-03-31 15:38:40] |
User311344 - Posts: 142 |
Thanks for reply. I sent my study to my friend and he runs it now, and reports only 480/480 non-zero depth levels for crude on Denali. So why he doesnt have 800/800? Thank you! Date Time Of Last Edit: 2020-03-31 17:06:58
[2020-03-31 17:35:59] |
That is because the order activity is not providing that many levels. It is as simple as that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-31 17:36:21
[2020-03-31 17:41:25] |
No it's not because a test was made, where limit order put at price above that last 480 level price didnt show up on depth. You can test it by yourself. But let's continue this discussion in other parallel thread which has more info about it, including wierd behaviour of ES depth that is rock solid 480/583 levels for last 2 days which seems really unusual... Thanks. CQG data for crude CL has only 400/400 levels + SWITCH TO DENALI |
[2020-03-31 18:43:35] |
We did see were a limit of 480 levels is being placed. We will get that cleared, after the close.
