Date/Time: Wed, 05 Feb 2025 19:56:58 +0000
Varios Monitores
View Count: 530
[2020-03-31 15:09:37]
User366703 - Posts: 1
Buen dia, les pido ayuda ya que no puedo encontrar la opcion para usar varios monitores.
gracias
[2020-03-31 18:04:59]
There is no specific option for multiple monitors, you just need to move your charts to the monitor you want to view it on.
Refer to the information here for detaching a chart window:
Detaching and Attaching Chart Windows: Detaching a Chart
And also refer to the information here for running multiple instances:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method)
