Date/Time: Wed, 05 Feb 2025 20:01:02 +0000
[User Discussion] - DOM
View Count: 443
[2020-03-31 08:34:55] |
User904434 - Posts: 57 |
Why I see sometimes on DOM only 1 row of data on Price Ladder? I should see 10 from buy and sell.
[2020-03-31 09:22:43] |
We do not know in your case. You are using the Interactive Brokers data feed and we do not provide technical support for that. We recommend using a Sierra Chart provided data feed: Real-Time Exchange Data Feeds Available From Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-31 09:23:01
