Date/Time: Mon, 25 Nov 2024 18:33:08 +0000
Compact Tools Value Window
View Count: 1913
[2020-03-30 19:11:10]
User750920 - Posts: 278
Hi, There are instances where I have two or more studies in a Region. For example two ATR studies (one for the current bar and one for an average of 10 bars) in say region 2. When I view the values in the Compact Tool Values Window only one study in that region show up. Sometimes that is desired other times I want both to be able to be viewed. How do I do this.
Thanks.
[2020-03-31 09:30:18]
You need to use the larger Tool Values Window:
Window, CB and CW Menus: Tool Values Window (Window)
[2020-04-01 20:45:08]
Thanks.. may I ask that you eventually allow more than one... even 2 in the compact window as the larger tool values window takes up too much room (screenspace) for active use - at least for me.
[2020-04-02 07:20:19]
You can customize the Tool Values window:
Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line
[2024-02-07 12:20:39]
User840539 - Posts: 25
I was looking through documentation but could not find how can I include a study subgraph value to shop[ up in the Compact Values Window. I have to use a tiny little Tool Values window just to display the value of a subgraph that I need, which then sits on top of candles on other Chartbooks when switching back and forth. Is it possible to display a study (subgraph) value in the Company Values Window after all?
[2024-02-07 16:55:23]
John - SC Support - Posts: 36262
The Compact Tool Values Window will not show the values of other studies in Region 1. But if you move your pointer to another region, it will show the values of the subgraphs for the studies in that region.
[2024-02-07 17:03:28]
Right, that I can do. But what if the study is in region 1 (same as graph) and is on left scale y-axis?
