Date/Time: Thu, 06 Feb 2025 00:00:01 +0000
[User Discussion] - Spreadsheet: Record Non-Intersected Swings
View Count: 560
[2020-03-30 18:30:01]
User190501 - Posts: 96
Hi all,
Using the Swing High and Swing Low study while showing extended lines of the level of each swing until intersected with price. Is there a way to record only the swing high/lows that are not yet intersected with the price in spreadsheet columns.. i.e when column to record all the non-intersected swing highs and another column for the non-intersected swing lows? I am adding a chart here to clarify as well... The objective is to use these columns to set targets for the new entries... for example whenever there is a new buy entry, the target will be set to the closest non-intersected swing high or the one that is away from the entry price by a threshold of x ticks ...
imagenon-intersected-swings.png / V - Attached On 2020-03-30 18:28:47 UTC - Size: 83.04 KB - 207 views
[2020-04-08 19:27:43]
Any ideas ? This is posted since 3/30 !
