Date/Time: Wed, 05 Feb 2025 19:59:42 +0000
Sierra - Robomarkets
View Count: 527
[2020-03-30 18:09:42] |
SpikeToshiro - Posts: 2 |
Hello, I have question, how to connect my broker (Robomarkets) to your platform. Thanks for your help. |
[2020-03-31 08:23:24] |
Unless Robomarkets supports one of the Trading services that Sierra Chart supports, you will not be able to connect it. Refer to the information here: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
