Date/Time: Wed, 05 Feb 2025 20:15:05 +0000
IB on 15 min chart wrong
View Count: 720
[2020-03-30 17:15:21] |
User97684 - Posts: 136 |
Hi, Pls help - how can I fix the IB study to show the correct IB levls? It looks like it is waiting for candle to finish forming, to then attach the IB to it. Thanks a lot, http://www.sierrachart.com/image.php?Image=1585588285276.png |
[2020-03-30 18:55:49] |
We are not understanding this. Can you provide more details. What is the time range you want for the initial balance?
[2020-03-30 20:28:33] |
Thank you, It IB range is 1 hour, from 8.30 to 9.30 Chicago time zone. The IB Hi today was around 72 ish, but my 15 min chart put it in the 80s.
[2020-03-31 04:59:44] |
What are the Session Times of the chart set to? And what are the Input settings of the Initial Balance study?
[2020-03-31 10:23:33] |
Hi, Thank you - The session times are set to 8.30 to 15.15 ( i use the chicago time zone setting for the chart ). The Ib settings were 8.30 to 9.30 . All sorted by changong the End Time to 09.29.59 instead of 09.30 on the 15 min chart |
2020-03-31_1114.png / V - Attached On 2020-03-31 10:23:05 UTC - Size: 174.75 KB - 220 views |
[2020-04-01 07:51:37] |
Yes that does make sense.
