Date/Time: Mon, 25 Nov 2024 09:45:52 +0000
Any plans on Index data feeds?
View Count: 1301
[2014-01-11 20:53:15] |
esMike - Posts: 69 |
Curious if you are planning on adding the Index feeds for $SPX(S&P 500), $NASX(Nasdaq Comp), to your live service. It would be nice to have them here rather than needing to subscribe to barchart.
Date Time Of Last Edit: 2014-01-11 20:54:24
[2014-01-11 20:58:07] |
Yes. This is absolutely planned.
[2014-01-12 06:34:24] |
tobi - Posts: 351 |
In which data feed will these be available?
[2014-01-12 08:29:17] |
This will be part of the Sierra Chart Real-time and Historical Futures/Stock/Index Data Feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-12 08:29:26
[2014-01-30 16:55:52] |
Is there any estimate of when these might be added? Spring 2014 perhaps?
[2014-01-30 18:06:59] |
We expect these will be added in February.
