Date/Time: Wed, 05 Feb 2025 20:02:36 +0000
new account
View Count: 480
[2020-03-30 15:37:59] |
samuel robatel - Posts: 4 |
hello, I would like to open a real account with you but I am not sure that I understood your system correctly. I start on future contracts and I would like to train on the bund the evening after work. I saw that you have the replay system that's great, however you could tell me which subscription to take and what to do please ? could you also tell me the price to pay. thank you
[2020-03-30 17:39:43] |
In this case you just need the Sierra Chart Historical Data Service for data which can be replayed which is included with our Standard service package. The cost is 26 USD per month. For Sierra Chart pricing, refer to this page: Description of Service Packages and Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-30 17:39:57
[2020-03-30 19:51:26] |
ok thank you however I would need the market profile and volume profile tools which apparently are in pack 5 and if I take pack 5 I find the eurex in your sc data flow
[2020-03-30 19:52:34] |
excuse but it's a bit new and complicated for me your system
[2020-03-31 09:33:51] |
Yes you would want to use the Advanced service package 5 and historical EUREX data is included which can be replayed.
