Date/Time: Wed, 05 Feb 2025 18:53:13 +0000
Brent price multiplier
View Count: 453
[2020-03-30 10:59:45] |
User816220 - Posts: 80 |
The price multiplier for the CME Brent contract (BZM20_FUT_NYMEX) seems to be off by 100. The intraday chart shows the price as ~0.26. Excluding the current day, the daily chart shows the expected prices.
[2020-03-30 17:14:46] |
This is now resolved. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings After doing the above: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
